Jazigo
- Joined
- Feb 9, 2025
- Messages
- 238
- Likes
- 214
Yeah i hear youThe ridiculous thing is that this small, inexpensive device outperforms preamps costing four or five figures—and not just in terms of measurements.
Both my friends and I used to own preamps in that price range.
For a long time now, however, we’ve been using headphone amplifiers—from brands like Violectric, SMSL, Topping, and Singxer—as preamps. That has absolutely nothing to do with the price, but with the result.
An additional switcher solves any input or output issues.
But of course I don't care if someone pays much more for much less.
Thanks!Thanks for another superb review @NTTY! Do you know if you will test the SMSL D400 MK2? I think it looks super smart in black, but I simply don't buy audio gear without a third-party verification. (I doesn't have a ground-lift switch, which may or may not be an issue)
while utilizing ultra-precise relay volume control to eliminate channel imbalance.
Again, seems to be just like Topping L70Thanks for the review! I'm a bit confused about the analogue volume. When I read that it suggests that it's a analog potentiometer. I was curious if it came with a remote. It does.
To me that would suggest an old school motorized pot. That doesn't appear to be the case here from your picture. Is it some kind of digital controlled analogue ladder resistor volume? - OH never mind... found it!
You may want make a note about how the volume works and note the remote in your review!
Dac output vrm goes up to 10+ and then a sota analog preamp (instead of digital attenuation) is there to attenuate in one cheap gadget. Well, not sure how it really matters but why not.What exactly do you mean?
That’s not quite right.The H in H200 is probably the best clue to the intended use is with headphones or as a pre-amplifier with limited two-input capability. The specifications list the power output into various resistive loads, but not the output voltage, suggesting the design intention is solely as a headphone amplifier.
From the pictures of the inside there are at least 15 relays on board, with 13 likely to be used for the volume control. Although the durability claimed by Omron for the G6K-2F-Y relay is impressive (greater than 100,000 operations, depending on switching current) to have so many in the signal path is tempting the fates.
Brilliant performance - looking forward to expanding the number of inputs.
This is a fundamental issue with this type of device.Thank you NTTY for another splendid review. I just wonder if more than two switchable inputs (one XLR and one RCA) could make this jewel even more flexible for those who have multiple sources. As it is, one should treasure the ability to use the high gain to bring the output in the region where the amplifier performs best (typically in low gain mode, at least for Class D like the Hypex Nilai 500). BTW, I could not see an output vs. distortion chart (maybe I was distracted).
What do you mean by "whether the preamp adds any noticeable value"?Thanks for the detailed review. The H200 looks particularly interesting as a headphone amplifier, but I think the most useful part of a review like this is how it performs in an actual listening setup rather than just the specifications.
I’d be interested to hear how it compares with similarly priced amps, especially regarding background noise with sensitive headphones, volume control, and whether the preamp section adds any noticeable value. Those practical details can make a bigger difference when deciding whether an upgrade is worthwhile.
In terms of measurements, the H200 performs well not only against similar and similarly priced units but also easily holds its own against—and in some cases outperforms—many devices costing 10 to 20 times as much.Thanks for the detailed review. The H200 looks particularly interesting as a headphone amplifier, but I think the most useful part of a review like this is how it performs in an actual listening setup rather than just the specifications.
Here are few pictures of the inside:
I only have a Motu Mk5 that can output max 21dBu not 23+dBu. I could test.As I'm just tinkering (but have no intention to buy one at this point), can H200 accept input higher than 5vrm? For example, how about Topping e50ii's max output, 11.3vrm?
You’re not the only one; I actually wrote something about this in post #30.Great review thanks.
As the happy user of a Pl200 CD player (one of my best recent audio purchases) I'm always interested in what this company does and always ready to open my wallet.
I have been looking for a high quality control centre for my (now sold) active Dynaudios and (current) hypex power amp and passive speakers + HD800 headphones for a while now and this comes so close. Great measurements, great form factor, remote and great volume pot.
But.. too few inputs, no DAC so no digital inputs. It just cannot accommodate the variety of sources I have at the moment. Phono preamp, SMLS PL200 line out or digital out (depending on which has the better DAC) and optical out from my Raspberry pi +Allo signature Hat.
Also switching inputs from a menu is just something I'm not interested in doing. Give me a dedicated knob or clearly marked dedicated buttons.
As it stands, it cannot replace my Benchmark DAC PRE. Same form factor, DAC included, 6 (!) inputs between analogue and digital, clear input selector in the front and fantastic volume pot. Headphone amp too! Sadly, it comes with no remote and the USB DAC is obsolete (but I use the SPDIF in). Also switching outputs on the Benchmark is great: when you plug your headphones in it automatically silences the line out towards the speakers. Brilliant.
I'm sure the device I have in mind would be much more expensive but I cannot be the only one with this use case.
Anyhow once again great unit for a lot of people and great review!
