- Joined
- Aug 5, 2025
- Messages
- 34
- Likes
- 50
Hello ASR members,
We're excited to introduce the H200, our new high-resolution audio interface designed to deliver exceptional sound quality for both professional and desktop audio applications.
Whether you're a headphone enthusiast, a content creator, or someone who simply appreciates high-fidelity audio, the H200 is built to elevate your listening experience.
Key Features:
Pure, Lossless Signal – Fully Balanced Discrete PLFC+ Circuit
The H200 features a fully balanced discrete PLFC+ circuit design. Unlike conventional integrated chip solutions, the PLFC+ circuit is precision-built with carefully selected discrete components, maintaining a true balanced architecture from signal input to output – effectively eliminating common-mode interference and preserving the music's original dynamics and detail.
Three-Level Gain Adjustment for Precise Matching
The H200 is equipped with three switchable gain levels – Low, Medium, and High – ensuring optimal performance across a wide range of headphones and IEMs.
Low Gain: Specifically optimized for high-sensitivity IEMs (in-ear monitors). The noise floor is virtually inaudible, allowing every subtle detail to shine through with exceptional clarity.
Medium Gain: Perfectly suited for most over-ear headphones, delivering a balanced, composed, and natural sound signature.
High Gain: Provides ample driving power for high-impedance, low-sensitivity flagship headphones, unleashing their full potential
Linear Regulated Power Supply for Stable, Long-Lasting Output
The H200 is equipped with a custom high-power linear power supply, providing the unit with a continuous and exceptionally pure power source – capable of handling even the most demanding dynamic music passages with ease. Precision-selected, low-temperature-coefficient resistors ensure that performance remains unaffected by ambient temperature changes, keeping the unit in peak operating condition at all times. Multiple protection circuits – including DC protection, overvoltage protection, and overload protection – safeguard both the device and your headphones around the clock for peace of mind.
Redefining the Boundaries of Sound – Ultra-Low Distortion, Wideband High Resolution
The H200 achieves an ultra-low distortion (THD+N) of just 0.00007% and an impressive signal-to-noise ratio of up to 131dB, reducing noise and coloration to near-inaudible levels. This delivers a pitch-black background and pure, authentic sound reproduction. With a wide frequency response ranging from 20Hz to 100kHz (-0.5dB), the H200 effortlessly captures every subtle nuance of high-resolution audio.
Functional Design
Technical Specifications:
H200 – High Resolution Audio Interface
Professional sound. Desktop-friendly design.
For more details, please visit our official website: https://www.smsl-audio.com/portal/product/detail/id/950.html
We look forward to hearing your thoughts!
Key Features:
- Fully Balanced Discrete Circuit: The H200 features a fully balanced discrete PLFC+ circuit, precision-built with carefully selected components.
- Ultra-Low Distortion, Wideband High Resolution: The H200 achieves an ultra-low distortion (THD+N) of just 0.00007% and an SNR of up to 131dB – delivering a pitch-black background and pure, authentic sound reproduction.
- Dual Function: Headphone Amp & Pre-Amplifier: The H200 is not only a headphone amplifier but can also function as a preamplifier, allowing for easy connection to active speakers or a power amplifier.
- Linear Regulated Power Supply for Stable Output: The H200 is equipped with a custom high-power linear power supply, providing clean, stable power even during demanding dynamic passages.
Functional Design
- Balanced & Unbalanced Inputs/Outputs: Balanced inputs reduce interference between channels, delivering cleaner, more accurate sound reproduction.
- Remote Control: A full-featured remote control is included for convenient, effortless operation.
- Compact & Durable Build: Designed with a robust chassis, the H200 fits neatly into any desktop setup.
| Parameter | Specification |
| Frequency Response | 20Hz – 100kHz |
| Gain Levels | Low / Medium / High |
| SNR | 131dB |
| Inputs | Balanced,Unbalancced |
| Headphone Outputs | 4.4mm Balanced,6.35mm Unbalanced |
| Pre-outputs | Balanced,Unbalancced |
| THD+N | -122dB,0.00007% |
| Display Panel | 1.9" IPS LCD |
