| CD Player | Native Pitch Error out of the CD Player | Pitch Error out of SMSL D200 | Pitch Error out of SMSL PS200 | Pitch Error out of Topping D50III | Pitch Error out of ASUS ESSENCE STU | Pitch Error out of SMSL D200 + G1 |
| Accuphase DP-70 | -1ppm | -1ppm | -1ppm | -1ppm | -1ppm | +4ppm |
| Pioneer DP-D9 | -16ppm | -16ppm | -16ppm | -16ppm | -16ppm | +4ppm |
| Yamaha CD-S2000 | -16ppm | -16ppm | -16ppm | -16ppm | -16ppm | +4ppm |
| Revox B 226-S | +150ppm | +150ppm | +150ppm | +150ppm | +150ppm | +4ppm |
Indeed, I am one of someBesides, apart from the ritual of unboxing a CD, sticking into the transport, looking at the spinning disc, etc. which some find exciting,
Been there, done that, boring. Easier to subscribe to whatever online music streaming.why not extract a FLAC copy from that CD onto a USB flash drive, plug it into a router which makes it visible on the network via DLNA, and play it directly via the DAC?
Thanks for the tips. The difficulty for the DIYer is to implement the input word clock. Now there is the new Cirrus Logic CS2600 that, at least on paper, makes things much easier as it is a one chip job.You could daisy chain the word clock output from one device to the other, this method work fine if you don't have several equipement to synchronize.
The best approcah is too use a Word Clock Distrubution amplifier as this one from Ross Video.
WDA-8409
Distribute word clock signals reliably with the Ross Video WDA-8409 Word Clock Distribution Amplifier—featuring 8 BNC outputs, selectable 75Ω termination, looping input, up to 192kHz sampling, openGear compatibility, and remote monitoring via DashBoard for professional audio and broadcast...www.rossvideo.com
Some advices:
Use proper video cable with 75 Ohms connectors and wire, don't mix with 50 Ohms BNC connectors. BNC connectors must be crimped not soldered.
Always put a 75 Ohms terminator on the last output.
It's a good pratice to monitor the word clock output with an oscilloscope.
The square signal should be pristine with but minimum noise, measure the output of the clock and the last output.
Mutec specifies its MC3+ clock accuracy as <0.1ppmI briefly looked at the competition, and I'll mention only one example of external clocks specifications.
Well, you don't know your ADC impact here.We get less precision, but still a very good 4ppm (of no concern).
But what the heck, why is it more?
Well, nowadays, audio networks are pretty much everywhere in pro studios.the pro's need this sort of device to keep everything synced
andThe bottom line of it, as I read it, is that this 500€ device is useless.
Please, don't tell this to people spending 50k for a dCS clock!Thanks for the review.
Is the dCS CD player any more tellable?Please, don't tell this to people spending 50k for a dCS clock!
Indeed. (Or, in fact, a -5 ppm error, since it was -1 ppm.) We are talking about differences on the order of normal sample variation here.Well, you don't know your ADC impact here.
It's very possible it introduces this 4ppm shift.
Your 1ppm result being, in that case, a -3ppm error added to the same 4ppm shift.
Because they can charge that much for it? Also, this has to be a fairly low-volume item in a fancy case, and I can't imagine that an OCXO is that cheap either given its usual fields of application. (I just checked, and you can buy a small 10 MHz OCXO board for less than 20€ on Amazon. That's actually not bad. If you want to buy just an OCXO at a distributor, you're looking at the 30-40-50€ range, though even 10 ppb parts can go over 100, and if you insist on 0.2 ppb it'll be over 1000. Those cheap boards may be sporting used OCXOs from decommissioned telecoms equipment or something. All of that old 2G and 3G gear must have gone somewhere after all, and for a smart recycler an expensive part like an OCXO means easy profit.)Why does it have to cost so much?
I would think that matching aesthetics is exactly the point. It's not a bug, it's a feature.And is there any reason, apart from aesthetics, it needs as large a box as the DAC and CD player in the same line?
and
" And the protocols used have to include efficient clock sync."
results into what final conclusion ??
Which isn't very smart. Because, as everyone should know, the power cable is the most critical component in the audio chain. Beginners
It’s even sillier when you for that money can get new balanced audio gear and run xlr cables instead
