SMSL DS20 Portable DAC & HP Amp Review
Rate this portable DAC & HP Amp:
    Votes: 3 1.8%
    Votes: 11 6.6%
    Votes: 59 35.5%
    Votes: 93 56.0%
This is a review and measurements of the SMSL DS20 balanced, portable (battery operated) DAC and headphone amplifier. It was sent to me by Aoshida Audio and costs US $190.
I am usually not a fan of transparent covers on electronics but this one is so well done that I approve! :) The enclosure is very solidly built metal which while heavy, oozes feeling of quality as does the glass cover. The white LEDS in the middle nicely show the current volume. Others indicate charging, USB class, etc.
Nice to see (true) balanced and unbalanced headphone jacks:
SMSL DS20 Portable DAC Headphone Amplifier Battery Phone 44 mm jack Review.jpg
While the multi-mode power button takes some getting used to, the rocker volume control is buttery smooth. It does have rather large steps though.
The entire back of the unit is magnetic and rather strong too as it kept sticking to my metal bench! It is made so that you can attach your phone to it. So you can put aside your rubber band!
In the interest of time, what you are about to see is abbreviated set of measurements, focused on balanced 4.4mm output. Company documents that the 3.5mm jack outputs half the voltage which means you get quarter of the measured power you see below.
SMSL DS20 Measurements
As noted, the volume control is rather coarse, jumping from 3.8 to 4.5 volts. I like to see 4 volts but gave the benefit of doubt and tested at 4.5 volts:
This is shockingly good and quite unexpected! We are talking very competent desktop class performance:
Likewise, dynamic range at 4.5 volt is superb for this class:
SMSL DS20 Portable DAC Headphone Amplifier Battery Phone dynamic range Measurement.png
But not the 50 millivolt output:
So highly sensitive IEMs may expose some noise.
Key for portable devices is amount of power and we have quite a bit of it here for this class:
SMSL DS20 Portable DAC Headphone Amplifier Battery Phone Power 300 ohm Measurement.png
SMSL DS20 Portable DAC Headphone Amplifier Battery Phone Power 32 ohm Measurement.png
This is well above what you get out of a dongle and you have a battery here to boot.
The SMSL DS20 turns in impressively good numbers for a portable DAC and headphone amplifier. The former aspect, is desktop class though the latter can be outdone with desktop amps. But not with dongles. So if you have any worries of draining the battery on your phone while enjoying music, the DS20 makes an excellent option.
I am happy to recommend the SMSL DS20.
Very good performance but I wonder just how many need something like this any more. Also, I like to see properly rounded corners and edges on something that is likely to go in a pocket.
Makes me wonder why DAP are still a thing...
This one is not a DAP. It has no display or local storage. It just has a battery, DAC and headphone amp.
I think it is too heavy to go into any pocket. It is something you carry in a purse/bag for long commute/flight.
That's what I'm saying : Why buying a (assuming big/heavy high end) DAP when you can pair your phone to such portable DACs.
@amirm any sense of how easy it would be to open it up to replace the battery? Similar devices seem to hit this issue quite early, in part due to the impact of needing to hit a challenging BOM on the quality/longevity of batteries.
This looks interesting and I want one just based on how it looks and performs. It's a maybe on if I would actually find it useful though!
It also fills my mind with questions. What sort of headphones would benefit from this sort of power? Can it charge my phone as well or is the battery only for powering itself? If it won't charge, how do I keep my phone charged while this is occupying the USB? Carrying this, a battery bank, phone and headphone is quite a bit more weight than just phone and a bluetooth headphone.
One way I'm thinking about wasting money enjoying music better is by upgrading my perfectly OK AKG Y50BT headphones so this plus some corded headphones could be an upgrade instead of better bluetooth ones. I'm wondering why I haven't seen many tests of bluetooth headphones here on ASR. Are they not considered to be that good, too tricky to test scientifically or other reasons?
Thanks for the review @amirm
This could be a good chance to look, in an "official review", at the potential issues with the cs43131 that @jkim and others have been studying
Reserved for specs...
@amirm , @SMSL-Mandy , or whoever the power that be at S.M.S.L., nice to keep seeing well measured 2 channel DACs but when, or are there plans at least, would a 4 channel DACS (well measured ones too of course) be launch, so people can use them with their 2 channel stereo systems that required two independent subwoofers with room correction such as Dirac Live bass control?
I am frustrated to keep seeing new 2 channel ones but no 4 channels ones that could work with Dirac's DLBC, vis USB, and/or HDMI input connections. I guess Topping has the 7 channel one, but if SMSL can do a 4 channel one it would be very nice.
CS DAC chip; is there a DRE filter disable?
Storage for one. iPhones and many Android phones lack SD slots.
But it’s a niche product anyway. The vast majority of people use their phones for listening to music on the go.
It's a great performing unit, but it's way bigger than a dongle. For OTG, I don't know why the use case for most people would not be a quality dongle, like, say a Hidizs S9 Pro+ Martha paired with a high quality IEM, Such a setup would be smaller, lighter and give all the power and performance needed for most any IEM and would be at least $50 cheaper as well.
As always, great review, Amir.
