Herbert Shooler
- Joined
- Jan 27, 2025
- Messages
- 56
- Likes
- 100
How long untill we get a dac where you can dial up the 2h,to say-40db etc..will such technology kill off the use of tube? get the 2h but keep very low noise...etc
They didn't.Not sure who at SMSL approved spending R&D $$$ on fake tube modes over a standard feature like peq.
I actually think it may be 5 colors, seems like the “H” next to USB is purple, but it’s a little difficult to tell with the quality of the image.Four (!!) different colours on that little display, serifs mingled with non-serifs, different sources on top of this, omg why is this not diminishing or does not ruin the verdict no matter which sq it delivers?
It's finally happening. They are starting to cut cost. Topping will follow suit soon.sheet metal
Indeed, you are right, it's purple colour, they put 5 (!!!) different colours on it!!!I actually think it may be 5 colors, seems like the “H” next to USB is purple, but it’s a little difficult to tell with the quality of the image.
And let's not forget Sabaj.
That is correct; however, SMSL also manufactures devices for other entities—such as Aoshida and Shenzhenaudio—in addition to their own line.
I challenge anyone’s hearing to be able discern harmonics -140dB under the fundamental or under 1% THD. It’s a horse $#!+ argument.I think it's to counter objectivist comments about products having distortion that is TOO LOW and sounds cold and analytical, and steer slightly towards the warm and cosy sound of tubes with much more 2nd harmonic in particular.
There've been many products that simulate tube distortion over the years, and they don't stick around. The sound comes from the romance and the glowy things. I had a Carver amp 25 years ago; honestly by the time I switched the cables to the simulated tube outputs I forgot what the regular outputs sounded like. They both sounded fine.How long untill we get a dac where you can dial up the 2h,to say-40db etc..will such technology kill off the use of tube? get the 2h but keep very low noise...etc
I would have found it interesting if you had listened to the distortion settings? You mentioned the Tube mode distortion is low and is probably inaudible but dosnt one of those distortion modes add another 25db of distortion above the tube mode? Rich 3 at 2 volts has sinad of 80, is that even audible?The two companies have been the earliest in the race so no wonder they are still on top. SMSL though, had been going sideways on a few products though. So good to see them back to their roots.
SMSL are probably doing what Topping and Okto do with some their products, and use the ESS THD Compensation function. This is intended to minimise the distortion of the completed product, but these manufacturers appear to be offering the user the ability to increase 2H & 3H distortion. I think it's to counter objectivist comments about products having distortion that is TOO LOW and sounds cold and analytical, and steer slightly towards the warm and cosy sound of tubes with much more 2nd harmonic in particular.
Topping offer a fairly extreme Valve Mode in their Sound Simulation Function:
Wonder if SMSL will go upscale at some point and produce something to compete with Eversolo or MiniDSP, or if they're happy being among the top cats of the desktop market?This is a review and detailed measurements of the SMSL DO400 DAC and balanced headphone amplifier. It was sent to me by Aoshida Audio and costs US$499.
It is not quite visible but there are contours on top of the front panel sheet metal, giving the DO400 a higher end look. I expected the user interface to be revamped as well but it is standard SMSL UI. It is easy to use though so not a practical issue.
Back panel shows the usual connections:
I wish there was trigger out support though. And some would like HDMI ARC instead of I^2S.
Instead of running my usual measurements, I omitted a few and added a bit of others.
For these measurements I decided to upgrade to the latest version of Audio Precision software which finally supports WASAPI audio instead of having to use ASIO emulation. Was so happy to see this. I connect to the SMSL and I am shocked to see lots of distortion. SINAD was a poor 95 dB! I hunt around, change things, read the manual over and over again and still can't figure out why there is so much distortion. Frustrated, I switched back to ASIO and same problem persisted!!! I then remembered the so called sound color setting. Look in there and it is set to "Rich1" instead of "standard!" Switched it to standard and everything was well. I hope SMSL changes the default to standard. As otherwise, you have paid a lot of money for a product that underperforms a dongle when it comes to distortion....
SMSL DO400 Measurements
I started with volume set to 0 dB and XLR output:
Distortion is incredibly low at -140 dB! Noise dominates SINAD as usual, and places DO400 easily in our top 20 DACs:
RCA output costs you a bit but not much:
Since I was on topic of sound color, I decided to measure the impact of various settings:
As you see, it costs fair bit in performance. Strangely, "tube" mode is the same as Rich 1, at least in total THD.
I dug in more into tube mode:
It does push second harmonic but nowhere near what a real tube product would do. I doubt very much typical person can hear its impact.
Back to noise, performance is superb:
Jitter is absolutely clean with USB:
As is Multitone:
I didn't check which filter was active for our wideband test:
Next, I measured balanced headphone out. I found it super clean in low gain mode with plenty of power:
As you can see, in high gain with 32 ohm, it really smokes!That should be plenty to drive any headphone to any loudness level.
There is no negative, low gain mode so in this department, the DO400 turns in middling score:
So very sensitive IEMs may not be a good fit.
SMSL turns in some of their best engineering in the DO400. DAC performance is state of the art. And headphone output is very clean in low gain mode and very powerful in high gain mode. We could use a couple of other features and a very low gain mode for IEMs. But that is it.
Price is reasonable for this class of product and I like the new front panel.
I am going to recommend the SMSL DO400.
When I got mine back in 2023, it was set to standard by default and not one of the colored options. I don't remember many DACs with PEQ being available at that time, except the RME ADI-2 ( I have one too) and it was 2x the price of the SMSL. So you have to consider that this DAC came out in 2023.A "coloured" factory default setting is a no-go for me. Probably many won't know.
Hope such "brilliant ideas" will not spread.
And no PEQ...
Oh, thanks, I thought it was new, must have misread it.When I got mine back in 2023, it was set to standard by default and not one of the colored options. I don't remember many DACs with PEQ being available at that time, except the RME ADI-2 ( I have one too) and it was 2x the price of the SMSL. So you have to consider that this DAC came out in 2023.
I contend that “low order” harmonic distortion created by many tube amp circuits is not audible. What people are hearing instead is the roll-off at both high and low frequency extremes (i.e., “warmth”) and the low damping factor (i.e., “tubby bass”). Distortion has almost next to nothing to do with “tube sound” unless the distortion is so extreme that the harmonics are something like 50dB below the fundamental or the THD is exceeding 20%.What Topping and SMSL are understanding is that what people actually like about tubes is low-order harmonic distortion, especially 2nd order -- and IMO, I don't think there is really a lot more to tube sound than that. How much more ideal it is that the this effect can be introduce more perfectly with solid-state design than actual tubes.
There is very little doubt that 2nd order harmonics are at worst benign and, for many people, warmer and more "musical" experience than a distortionless design. IMO, 2nd/3rd also mask other distortions i.e. higher-order harmonics.
BTW, I still enjoy my tube preamp from time to time.
Well look at that, 16 of the top 20 highest measured SINAD DACs are either Topping or SMSL.
