SMSL DO100 PRO - HDMI ARC DAC
Does this automatically switch input? I want to use optical, hdmi arc and usb.
Sorry where is this switch button again? Don't see it.
Just wanted to clarify, this unit, the DO100 Pro does NOT have this switch. Its not underneath, or anywhere on the case. It's also not mentioned anywhere in the manual, or website, so not totally sure where that image came from.
I just leave it on 99 volume as I want maximum output (5v) to my headphone amp. I also assume that this delivers the best signal to noise ratio, but I don't believe it's been measured by amir.
If you truly wanted just 4v output, you'd have to lower the volume and measure the output until you hit 4v.
That switch is present on the DO200Pro, but not on the DO100Pro. The model numbers are similar, so it's easy to get them confused.
DO100 pro MCU V1.3 has now been released on the SMSL support website, this time having the proper flashing tool with English language, I have carried out some very basic tests and it suggests that the filter assignment remains the same between MCU1.1 and MCU 1.3 files, however, the sound signature has been improved (subjective opinion).
The firmware that the DO100 pro originally shipped with was MCU1.0 and I for one, felt that the sound of the DAC became too sterile with less bass definition when I upgraded from the original FW to MCU1.1, it now seems that MCU1.3 has fixed this.
How did I confirm my findings between MCU1.0 and 1.1, well, I asked SMSL to send me a copy of MCU1.0 which they kindly provided and I went back and forth between MCU1.0 and MCU1.1
when selecting the same filter for example Minimum phase fast roll-off (FL7 on 1.0 and FL6 on 1.1) the sound was different with 1.0 sounding better to my ears (better bass definition, less treble harshness and better instrument separation)
I know subjective opinions don't hold much value here but I still felt obliged to mention this for those of you that upgraded your DAC and felt the sound somewhat degrade.
Also, I would invite those of you that have this DAC and have relevant measurement equipment, to request the MCU1.0 and MCU1.1 FW from SMSL and perhaps measure it's output specifically for filter impulse response, frequency response, 1khz FFT and IMD to verify whether or not what I have heard can be shown measurably.
The only thing I am able to verify is the impulse response characteristics and it does seem the filter response characteristic is closer to MCU1.0 with filter assignment still being as it was in MCU1.1
Now in MCU1.3 the sound of the same filter FL6 more closely resembles that of MCU1.0 except the filter arrangement is
FL1 - Minimum phase slow roll-off low dispersion
FL2 - Linear phase apodizing
FL3 - Linear phase fast roll-off
FL4 - Linear phase fast roll-off low ripple
FL5 - Linear phase slow roll-off
FL6 - Minimum phase fast roll-off
FL7 - Minimum phase slow roll-off
Kudos to SMSL for releasing this firmware update.
This post is only intended to highlight that the new firmware has been released on the website and my subjective findings. I am not specifically stating that there was something broken in the previous firmware, the decision to upgrade sits with you, if you do upgrade, it would be interesting to hear your feedback on any perceived impact on sound quality.
Good afternoon. Thank you for your post. I flashed it on MCU1.3. In my opinion, after flashing, the sound character became warmer, the sounds became more prolonged, and the scene became more voluminous. The speed and emotionality have been preserved.;)
Buongiorno a tutti mi presento, sono Giuseppe un nuovo iscritto e sono interessato a questo DAC per rapporto qualità/prezzo, ma volevo qualche info, dovrei collegare un lettore universale Denon DBT 3313UD che ovviamente dovrei collegarlo tramite HDMI quella solo audio al Dac e poi l'uscita al pre e finale Rotel RB -RC1070 , questo modello che HDMI ARC va bene per il collegamento? Il Denon non ha ne uscite ottica ne ottica coassiale, quindi l'uscita aut RCA non e un gran che e vorrei migliorare l'audio. Adesso con il pre e finale ho collegato OPPO BDP 83 ma come meccanica di trasporto il Denon e superiore e vorrei migliorare la parte Dac, che ne dite? Questo Dac lo vedo interessante l'unica sua pecca a mio parere e non avere un display migliore con piu informazioni, ho visto il modello 200 pro ma non monta gli ESS Sabre purtroppo.
Hi @peppe69! Welcome to ASR.
Please use English here :)
Unfortunately the Denon's HDMI output can not be connected to the SMSL DO100 Pro, or any other device with HDMI ARC port.
To connect an external DAC to the Denon, you have two options:
1. HDMI Audio Extractor -> SPDIF -> External DAC
2. HDMI ARC Converter -> HDMI -> External DAC
PS:
Don't mind which DAC chip is inside the device.
Us humans have not been able to tell them apart for a long time now, even if our psyche and audiophile egos stubbornly refuse to acknowledge it.
Ciao, grazie per la risposta. Ho letto alcune recensioni per farmi un'idea dei DAC con un buon rapporto qualità-prezzo e mi sono imbattuto in questi modelli SMSL, che sembrano eccellenti. I consigli di AI mi indirizzano verso il D400 Pro perché, oltre ad avere un ottimo DAC, la sua implementazione è superiore a quella del DO100 Pro. Voglio fare un acquisto che valga la pena: devo pilotare una coppia di diffusori B&W 683 S1, che non hanno un suono particolarmente aperto, utilizzando un preamplificatore e un finale di potenza Rotel molto lineari. Non so quale scegliere.
