Yes, that was my question! Thank you for your answer!If you mean whether you can control the hardware volume from the USB host, no, that option has not appeared.
Yes, the front knob of the DL200 controls the volume of the RCA and TRS outputs.
Remember to set volume to 00 which is mute before you first play anything and increase it to find the right volume setting. It defaults to 99 which is full volume.Thanks for that. I have one coming in today and was hoping that was the case. I need to control volume going to my "full power" amp+JBLs. I assume any DAC or headphone amp with "preamp" features can do this, but it's good to know the SMSL won't blow out my speakers intentionally (fingers crossed)
What am I looking at here?Single ended out. Virtual balanced at DAC/REW
Second harmonic
6 hours stepped. Bal out
The value is pretty good, but the space is competitive even against SMSL's other products.For post 1251 the distortion of the ADC will also come into the picture in the last decibels.
But in my eyes crazy good values for distortion. Both DAC and ADC
Sure but so is the DX3Pro which is cheaper. There is alot of competition, like I said.And if the noise is not heard, the harmonics are under hearing threshold, -80dBr, even at -60dBFS.
So perfect for digital attunation. I use max 40 dB from quiet background up to loud for the neighbours
Still no usb cSure but so is the DX3Pro which is cheaper. There is alot of competition, like I said.
