SMSL DL200 firmware update not working
quagmire
Hi everyone,
I got a SMSL DL200 back in April which has been working very well. I saw that a firmware update (MCU, not driver) is available on SMSL's website so I wanted to get it installed on my unit.
The update comes in a ZIP file with an executable and a PDF manual:
First of
First of all the text in the updater is encoded in a Chinese character set so it appeared completely garbled (as you can see in @Maxicut's screenshot here) until I switched my language locale in Windows 11 to Chinese. After doing so I am greeted by this screen:
The text translates to:
Important Notes:
1. Before downloading, ensure your computer has a serial port or a USB-to-serial adapter cable.
2. Typically, the serial port's maximum/minimum baud rate requires no adjustment.
If the serial port speed does not match this program,
try setting both maximum and minimum baud rates to 2400 or 4800.
3. When updating code, first click the programming button in the upper-left corner of the interface,
then power on the device.
As per the instructions above and the manual, I unplug the power cord from the DAC and keep it connected via USB-C to my PC then try to run the upgrade by pressing on the Start button. However an error message pops up:
Translation:
Detecting target microcontroller...
Communication timeout! (2025-09-23 01:44:39)
What I've tried so far to attempt to fix the issue, to no avail:
- Changing the min and max baud rates to 2400 and 4800 using the rightmost button
- 4 different USB-C cables (3 USB-C to USB-C / 1 USB-C to USB-A) on different ports of my PC
- Switched from USB 2.0 to USB 1.1 on the DAC before powering it off and pulling the power cord
- Clicking over and over again on the Start button
I sent an email to SMSL's online shop support service ([email protected]) but they never replied. At this point I'm at a loss as to what to do.
I'd like to tag @SMSL-Mandy, @Maxicut and @jkim as the latter two people seem to have completed this firmware update succesfully.
Would gladly appreciate any help!
Make sure the driver is installed.
I already have installed the XMOS USB Driver unfortunately.
Hi everyone,
View attachment 477782First of
Translation:
Please try the following in this order:
- Disconnect the USB and power cord from the DL200
- Turn off and restart your Windows computer
- Launch the update program
- Connect the DL200 only via USB cable
- Check that the settings are correct
- Start the update
- Do not plug in the power cable until the update is complete
The exe comes with a pdf with instructions. Just follow them and it will works fine...
I think you have a wrong translation for the message at the end. So plug the power and it will update
I know.. but its not working... Its possible to check curent firmware?
You need to be fast to plug the power cable after clicking start... Like 3s max
power cable not helped..
正在监测目标单片机 ...
通讯超时 !(2025-10-02 08:00:27)
Monitoring target microcontroller...
Communication timeout! (2025-10-02 08:00:27)
Personally, I wouldn't take a chance of "bricking it" unless the original firmware is retained and recoverable with a hardware jumper on the circuit board (or some other recovery method that doesn't rely on a computer connection or anything external).
I don't know about the S.M.S.L. but some devices can be updated without overwriting/destroying the original firmware.
Or if it's got bad defect, or it's an important upgrade, and you're willing to pay to have it have it professionally un-bricked if necessary.
yes i remember now how i did the update, this is working...
plug the dl200 on a power strip with a switch
clic start and then switch on
it is faster than pluging the power cord
Are you successfully upgrade the firmware?
I am also interested but I am so scared of brick the device.
i think the update is limited to renaming the filters as they was not labelled correctly
so it is not necessary to do it
