SMSL DL100 DAC and Headphone Amp Review
Rate this DAC & HP Amp
    Votes: 4 1.6%
    Votes: 5 2.0%
    Votes: 51 20.3%
    Votes: 191 76.1%
the orientation of the XLR ports doesnt make a big difference
on the M300 you use your thumb to press the retention clip
the DL100 you use your index finger to pinch
its whatever - or you can buy clip less cables???? that's not in spec but its the wlld west out there
You are correct but for me I hate it and the fact left and right are reversed as I always hookup stuff from behind not from the front.
I guess it's a pet pev of mine coming from the broadcast world as Sony broadcast on their then old machines use to do this and they got an earful and even they changed it.
BTW we would never use clippless as we rather spend 20hrs taking a machine apart when a cable get stuck then just pull out the cable..
There are connectors where you have to apply serious force and in any case to put your finger underneath you have to lift the DAC (there is no space).
there are no problems if you have an single SMSL AMP and single SMSL DAC
their amps ship with the RC-8A
their dacs ship with the RC-8C
I have a few of the 8C models
you cant easily remote control TWO smsl dacs because the remote will control BOTH DACs but why would you want to use two of them?
Will there be any problems between two different - but colocated - SMSL products, each with its own RC-8C remote control?
Well, they should both react which could cause problems. Might be better to have one Topping DAC and one SMSL DAC instead.
This is the same technique HDCD used. I don't see an issue with it.
It’s not bad but it’s not perfect either. I would say the closest analog to this is the dynamic iris in projectors which is used to boost the contrast ratio performance. It is certainly better than the dynamic contrast ratio methods that actually dim the display bulb and make the display look like a flickery mess, but dynamic iris still isn’t native contrast. Say we have the brightest and darkest white points, the darkest from from a dark scene and the brightest from a bright scene. The white points won’t be shown at the same brightness when shown together as shown separately in their dark and light scenes. The instantaneous native contrast ratio will be worse than the overall dynamic iris enhanced contrast ratio. In an ideal world, I would prefer a true native performance that doesn’t scale across a runged ladder to increase the effective dynamic range, but I will take whatever gains I can get if and only if it is done seamlessly.
They provide a driver but it looks like it works without it (but only shows up as "headphones" for the device type).
Is there any benefit of installing their driver?
The driver unlocks the ASIO interface for, among another things, native DSD playback.
Installing the driver may also be required for updating the firmware.
If you get annoying clicks and pops, or there's a delay when starting music after a while of nothing playing, then you may fix these by installing the driver, then applying this fix:
That's all I can think of :D
If only this DAC headphone amp SMSL DL 100, which measures so beautifully!, had a parametric EQ per channel, an adjustable crossfeld and one or two (!) sub output per channel... it would really be useful on the market compared to the plethora of excellent DAC-Amps headsets... (because these implementations seem more useful to me than that of HDMI ARC).
You wouldn't get it at the given price then.
For a few dollars/euros more: around 50... but at least the sota race would result in a very useful device... Well, I would even add an adjustable loudness in the DSP pipe... Because in my opinion personal to me that I find :cool: ;) HDMI ARC useless with a product of this quality.
You're describing the RME ADI-2 DAC. But on Windows you can install an app to do all that.
Yes, I know ! But we would be far from the price of the RME...
As it is, this SMLS is excellent but in a crowded market. In fact, in my opinion, this race for ultimate performance should now be accompanied by useful features.
But as it stands, this device is remarkable of course and its performance puts it in a superior category like many others.
Respectfully that's a bit of wishful thinking. The amount of development and expertise that would be required to get feature parity with the RME is staggering. It's another degree of difficulty above something like APO or foobar2000 (filtering/computing on a modern PC). Then, you'd need a better screen and more controls. Assuming all this could be done, any price differential could then be attributed to support (RME is adding features years after the device was sold, and fixing them for a fair price if broken).
this is the cheapest smsl dac with iec with a budget CS chipset
if you are trying to get this smsl to make an RME out of a dl100 then the problem isnt with smsl... theyre selling a mousetrap and you're wanting to capture bigfoot
