SMSL DL100 DAC and Headphone Amp Review
Rate this DAC & HP Amp
    Votes: 4 1.6%
    Votes: 5 2.0%
    Votes: 51 19.9%
    Votes: 196 76.6%
Hello, i recently bought headphones, 7Hz x Crinacle Zero:2 IEM. Now i think about purchasing this DAC+AMP. I'll be using 6.35mm headphone jack to connect headphones. I want to achieve SPL of 121dB. I know its too loud, still. Headphones is around 30 ohm, with sensitivity of about 108dB/V. My calculations show that i need about 900 mwatts to achieve this SPL. But I'm somewhat confused about output level Vrms. Does it matter? Can i achieve desired SPL with this DAC+AMP using 6.35mm headphone jack output?
I'm super curious why you need such a high spl?
Power is voltage squared divided by impedance. Thus, if it can produce the required power, its voltage output will be sufficient.
The sensitivity Amir measures is 94 dB SPL at 50 mV RMS, which is equivalent to 94-20*log10(50/1000) = 120.02 dB SPL at 1 V RMS or 0 dBV not 108 dB. Thus, 121 dB SPL requires 1 dBV or 1.12 V RMS. The DL100 can produce 1.5 W into 32 Ohm which is 10*log10(1.5*32) = 16.81 dBV. Much more than needed.
Amir measures the impedance at 29 Ohm. Thus, in the worst case of current limiting, voltage output is 29/32 lower than at 32 Ohm or 20*log10(29/32) = -0.86 dB lower, i.e. 15.96 dBV. Still more than enough.
For 121dB SPL Peak out of the Zero:2 you need 1.12Vrms, which at 29Ω translates to 43mW.
For this application, anything more than the Apple A2049 or JCally JM20/JM20 Max is utter waste.
Why do you want to destroy your hearing?
Thanks for the replies. I want to compare Zero:2 headphones to 7.1 surround speaker system at reference volume (105dB per channel + 115dB LFE), and 121-122 dB is about max peak from all speakers combined, and this happens rarely in the mix and for short amounts of time, so probably not too bad for ears. I think I'll buy some headphone dongle for my purpose. Thanks again.
You realize that with something right inside your ear it will cause significant damage quickly right?
How did you arrive at the combined maximum?
Assuming perfect correlation between the signals and zero means, the maximum SPL is 20*log10(7*10^(105/20) + 10^(115/20)) = 125.14 dB SPL. For uncorrelated signals with zero means, this is reduced to 10*log10(7*10^(105/10) + 10^(115/10)) = 117.30 dB SPL.
Don't put that sort of SPL directly into your ears, even for short periods ... it's not nice for listening to music, and it's not worth it given the real risk to your hearing. Honestly, it's just not worth it.
One loud sound impulse above 120dB can and probably will damage the delicate receptor cells in your organ of Corti, even if the impulse is very short.
I'd never willingly expose my ears to such noise, ~105dB at the listening spot is more than enough for me.. :rolleyes:
I simply added +6dB for every doubling in speakers. So, 1 speaker is 105 dB, 2 is 111, 4 is 117, 7 is about 121-122. LFE is always 115 dB, and while it adds SPL, but only to low frequencies. I'm not really sure about my logic, but it gives me approximate theoretical maximum.
For anyone worried about my hearing, thank you, but i know the dangers. In fact, i decided to record peak SPL from my test movies to get clear about what SPL I'm actually talking about. Measured using UMIK-1.
This blue line is 1 speaker REW sweep. Its 105 dB. Peaks and dips are result of me sitting here and holding mic, MMM gives a lot flatter response, anyway.
Red and green is some action scenes from two movies. This is their peak SPL. So while in theory SPL should combine to 120dB+, it only reaches to 110 dB bass, in this particular movie, and the rest of response is even lower.
To me those Movie 1 & Movie 2 peak levels experienced should be OK for your hearing, if it's just occasionally near those levels in the movie.
Delighted with mine. Use case is for the Arc input for sound from my TV. Works v well for music streaming too. I might yet swap it out for the Fosi ZD3 as I don’t need the headphone amp.
Hi, I would like to know if the TV remote can change the volume of this dac via HDMI.
Thanks in advance.
Thanks in advance.
It can, but might be tv dependent. The implementation isn't as great either since the dac's own volume doesn't change. For me the volume of TV reset to 100% on each boot.
DL100 provides some form factor changes and inclusion of HDMI ARC. Performance is more than excellent in every area, making for a compelling package despite its attractive price. I especially like its high current drive for headphones that have low impedance.
Sweet, This little sweetheart of a DAC/Amp confirms my feelings that DAC's and Headphone amps are totally solved issues that should be
available as low cost / high performing products. Ones that are completely transparent from input to output. The only final question here would be, at this cost how reliable a product can we expect? But at $179, there's not much to worry over anyhow. ;)
Salute
I have received it a few days ago, and like said in this thread, the HDMI volume control is finicky at best.
The sound is way better than the TV headphone out, and from memory, sounds more impressive than the SMSL M300SE.
Although I am using the optical connection to the TV, I still like to have an extra input option and I will still try with another cable.
Overall I am super happy with it, sounds great with my Topping pa3s
