For price, that largely depends on what territory you are in- I know the RME is comparatively more expensive in the US than the UK for example.A friend asked me for help as to indicate a SMSL DAC with SQ and price compatible with the RME Adi 2DAC FS.
Could anyone help me with the need of him?
VMV D1seA friend asked me for help as to indicate a SMSL DAC with SQ and price compatible with the RME Adi 2DAC FS.
For quality- is he looking for a combined dac plus headphone amp or just the DAC? Does he need any of the additional features the RME has. Does he need the balanced/ xlr line outputs of the RME or just the RCA outputs?
In terms of the measurements, pretty much any of the newer SMSL DAC should have pretty much the same "sound" as the RME (ie - transparent to the source)- have a look at the review index on here . The SMSL range seems to grow and shift monthly!
PS- I think you mean "comparable" with (equivalent to) , not "compatible" (works with)
Ok jimbob54,For price, that largely depends on what territory you are in- I know the RME is comparatively more expensive in the US than the UK for example.
Ok jimbob54,
Comparable or similar is more adequate!
The focus is sound quality!
The focus is SQ. Just this.You did not answer his questions as to what features and connectivity your friend needs or wants.
A DAC only or a combined DAC/headphone amp like the RME ADI-2 DAC?
A unique strength the RME ADI-2 DAC has is extensive onboard DSP features like dynamic loudness, PEQ and tone controls. If your friends wants similar functionality the picking is very slim indeed.
That doesn't tell the full story.The focus is SQ. Just this.
SQ wise, you probably can buy a $150 DAC that will match (more or less) the RME in its DAC function.
But then comes the rest : Functionalities
And quality if their implementation.
Most obvious examples:
Powerfull and performant headphones amplifier, EQ with "Loudness" function, comprehensive set of IOs, informative display, effective remote control, ...
Not to speak about warranty and support, frequent firmware upgrades (adding new functionalities),...
