adamjohari
- Joined
- Mar 6, 2021
- Messages
- 77
- Likes
- 59
Added the SMSL DA 9 into my cart. Then I removed it. Then I added it back. So forth
Hi folks.
SNIP
I received my order of Japanese made Stainless Screws to replace the original SMSL supplied screws that are on the underside of the SMSL DA-9.
I had to do some filing with a power screwdriver to get the diameter to fit in the original screw holes, they aren't a standard metric size, though they are a standard M3 6mm screw. Even the low-profile screw heads are extremely low profile but the screws I ordered had more than sufficient depth to ensure an ultra snug fit.
Guess which screws are the Japanese Stainless steel screws.
There is zero improvement in anything other then the tolerance of the screws. No sonic benefits at all, but it is a simple mod that anybody can do for piece of mind. I ordered some Aluminium screws also though they are special on order as they are ultra low profile heads so I will have to wait a little while for the screws to arrive, I've also ordered some titanium screws though I worry about using titanium screws in an aluminium chassis.
Here are the pics. Which would you prefer using?
Are you serious? You worrying about screws? "for piece of mind"? It is actually peace by the way Im sorry, but this just seems well, silly but hey what ever floats your boat. Just my opinion which I do believe is an acceptable thing to voice before the haters come out like hungry hounds.
That being said, still waiting for my replacement DA-9. I dont miss it much, I have a pretty decent class AB amp.. But will be nice to have it back and play again with the balanced inputs.
I did however, receive my acoustic panels today which I am excited about.. I wont go into it but had to say it Want to upgrade your DA-9? Acoustic panels.
Also, like your DA-9 my SU-9 has been playing 24/7 for weeks. I just shut off the amp and music is in repeat mode. Id say it is burned in.
First post of a long time ASR forum lurker.
Is it safe to say that the THD+N vs power graph posted by SMSL for the DA-9 shows the truth after seeing that the one measured by Amirm for the SA400 matches?
If so, the DA-9 is a bargain compared with the SA400, also with newer and better amplifier chips.
I am attaching the graphs for the SA400 from Amirm and SMSL.
@barchetta
Im glad you reordered the DA9 and not lose confidence on the product. Looking forward to your T&E for the 2nd time around.
You mentioned in your previous post that you utilized a valve preamp between your SU9 and DA9. And you said the sound is noticeably better than the SU9 connected directly to the DA9.
If you dont mind sir telling me the details of the sound improvement. Because I might going to do the same.
Thank you and stay healthy.....
It just sounds a bit smoother to me. It could be completely in my head because I want it to sound that way. I think I also enjoy the new meets old part of it. My preamp if I recall was sold in the 1960's and sounds wonderful with great tone controls. I think I like the easy to use tone controls as well. That is the best answer I can give you.
Some have also done that. But not on the SU9 and DA9. They claim significant sonic improvement too.
Thank you and regards....
Damn im excited I just ordered my DA-9. Hopefully it will come next week and I really hope it's as good as everyone has said.
Also I haven't yet decided on a dac so if anyone has any good budget recommendations I would be happy to hear them
iiWi just posted a long positive DA-9 review on YouTube. He was blown away by the performance for the price, says the DA-9 is a "market disrupter product" close to his personal favorite Hegel H90 amp in sound. I enjoy iiWi's reviews even though I disagree with many of his subjective views on the sound qualities of cables, DACs etc.
As compared to Zeos, his statements and descriptions are well researched and you can see that thought and prep time is put into each review. He provides lots of links and even indexes topics covered. That said, when he compares the sound of different DACs or streamers I tune it out.
...... Zeos is really on the other side of the spectrum, any gear he reviews it's as if he only just set it up minutes before, endless verbal hemorrhage with no actual criticisms....
I watched the review as soon as I read your post. I cant help but to smile because his excitement on the DA9 was the same as mine when I made my test. I watched the video from start to end and I enjoyed it. Thanks for sharing.
PS: The SMSL VMV Class A amp brochure you provided is cool. Thanks.
