SMSL D300 Review (Balanced DAC)
redjr
Wonder what the subjectivists will say about the "sound" of this DAC chip.
It holds its own sonic status just like many other DACs at this price point. Articulate, transparent, with wide dynamic vigor. I had the pleasure to sample this DAC for 7 days, along side my ESS based chip DAC and I was hard pressed to find any sonic nuances that were objectionable with numerous high-def and a few DSD tracks in my library across a wide genre of music. I only returned it because of a couple nits that I didn't want to use long term. That flush mounted dial was a gastly mistake, as anyone suffering from dry hands can attest. Please give me a weighty knob that I can grab between two fingers for manual control of features. Sonically it was clearly above par IMO. I'm glad Rohm is now in the DAC chip business.
redjr
Very nice looking DAC.
You should check out the Fiio K9. From a looks standpoint the competition can't touch it. There is simply simply nothing in the consumer consumer market that even comes close! I've never seen such a sleek and professional grade piece of kit. And it has specs that nudge ahead of D300. Waiting for Amir's review of it. I'm getting one for Christmas. :)
oneman
I do not understand why in those Chinese DACs are only one coax | one optical | AES iputs. Is it so difficult to make a DAC equipped with three optical inputs + three coaxial + two AES, just like it used to be in a past?
I guess it is also unbelievably impossible to make a DAC with at least one digital output
pseudoid
If this is a wHine-party, I want dibs too:
>> I want more XLRs, for both analog inputs and outputs.
Does ASR have a post for whiners like us? It could be interesting...:cool:
Paweł L
Yeah, 3 opticals instead of one, is what decent audio equipment should have to begin with, unless we add HDMI instead, since HDMI is starting to be a norm for many players. One of each really feels very budget oriented these days.
Wuzel
While it makes the device more expansive.
And only a few customer are need these....
And this few people can use a active switch for 20-60 bucks... whos the problem?
May Kasahara
Why is SMSL releasing another DAC in this price range? Don't they already have one for 399?
Problem solved!
Yesterday I saw two reviews on Youtube that probably answer this question.
SMSL Review 1
SMSL Review 2
In summary, I would argue that they come to the same conclusion. Yes, S.M.S.L already has DACs in this price range, but this one with the ROHM dac just sounds different. Less DeltaSigma (sharp, analytical) more towards R2R (musical). Of course, that also explains why just noticing and measuring numbers, here on ASR, could not detect this fact.
OT: Sometimes I think that is also the weak point of asr. Yes, I know this is about numbers but at the end of the day I just can't hear numbers, but that's another topic.
Veri
It is though, quite literally that. 100% DeltaSigma DAC, nothing multibit about it.
Wuzel
Problem solved!
SMSL Review 1
SMSL Review 2
For me it sound like a few bucks 'standard' dac - way behind the ESS/AKM Flagship DAC's. I think that's it why some people think its sound better - or more 'music'.
The ears overwhelmed with the massive information, special in high-band. When u hear some crappy devices or vinyl its hard limited in detail and high band - no overwhelming here :D
SMSL-Mandy
This is our first dac on Rohm Chip. D300 sounds more like playing vinyl, the felling more analog
Hapo
This or the Topping D30 Pro? I’ve always owned Topping and have enjoyed them, but the SMSL units are sleek and the screen looks cool.
...this is where I am aboot now...this video didn't really help much... (grin)
...I am liking the easy on the ears part of the equasion these days...
Hapo
...did you like the K9...???...did it sound like you hoped it would...???...
redjr
The K9 sounds great. I'm very happy with it. It's equally as good as my other ES9028Q2M based DACs. (I can very easily do basic A/B comparisons) with roon.) There's simply no audible differences that I can hear with my system. In addition, you get plenty of I/O options with the K9. Interestingly, to my ear, I'm favoring the sound using single-ended (SE) output > Freya S pre > Elac Navis active speakers.
If you're into build quality, the K9 bests the competition at any price-point. It's very substantial in every way.
Lupin
Using a plastic sheet over the PCB for structural integrity of the chassis does not really count as the pinnacle of "build quality" in my book. :rolleyes:
Personally I feel the K9 Pro is way too expensive for what it is and what it does. FiiO is banking heavily on subjective audiophile believes with the K9 Pro.
redjr
I can't speak to the plastic sheet over the PCB. I haven't opened mine up to see what's in there. I was simply observing the heavy casing and quality fit-n-finish. One is generally indicative of the other. I have owned/tested many of the Topping and SMSL recent generation of dacs and they seem less substantial. My K9 was a gift, so I can't complain too much. ;)
I'm finding the range of connectivity and versatility of the K9 fitting in nicely to my system, and I've found nothing objectionable about it's sound.
Snoopy
I've just ordered a D300. Shipped and fulfilled through Amazon so there should be no problems with warranty and return.
Measurements look good and at the same time some audiophile reviewers seem to really like it.
Going to use the DAC with the Singxer SA1
redjr
I don't think you'll be disappointed with the sound. I had a chance to listen to one for a couple weeks last year, shortly after it was released. I was impressed with sound. I felt like it matched anything I had in my DAC stable. You will likely have other pieces of gear in your playback chain that will hold back what the D300 can dish out. YMMV. Amir gave it a 'recommended'.
Snoopy
Will be using it with qobuz and my headphones. Focal Elegia and DC Aeon 2 Noire.
Should be ok together.
I have currently a Cambridge cxn V2 with a dual Wolfson DAC.. the D300 will be probably better
Chobabi
Hi everyone, new member here (long time lurker) and a new owner of this DAC. Currently I am experiencing an issue playing DSD files at native sampling rates w ASIO, all I get is a bunch of static. I have uninstalled and reinstalled the drivers but nothing seems to be working.
Current setup is PC > D300 > Passive Preamp (RCA)/THX 789 (XLR) > Genelec 8040b/Hifiman Arya 2021
When I just do regular PCM 44.1 it plays perfectly, and ASIO works perfectly fine with other hi-res FLAC files I have in my library.
Any inputs are appreciated.
