SMSL D200 DAC Review
Rate this DAC
  • Terrible (*)
    Votes: 3 4.9%
  • Mediocre (**)
    Votes: 1 1.6%
  • Good (***)
    Votes: 11 18.0%
  • Excellent (****)
    Votes: 46 75.4%
Hello Everyone,
This is a review and details measurements of the SMSL D200 DAC.
It was kindly sent to me by Aoshidaudio.com
SMSL D200 DAC - Presentation
This is a nice looking device with only one knob on the front. It reads PCM (up to 768kHz) and DSD (up to 11MHz or 22MHz depending on DoP or DSD direct).
It features a ROHM BD34352EKV DAC that offers two interesting options, implemented in this SMSL D200:
  • A classic Oversampling Filter selection : Sharp, Slow or None
  • A much less classic oversampling rate selection for the Delta-Sigma modulator : 16x or 32x
As for the rest of the technical description and features, I invite you to read to go to the SMSL site.
The specs are the below:
On the back we get:
  • XLR and RCA out
  • USB in
  • SPDIF (Coax and optical) in
  • Clock input too, for external synchronisation
  • Bluetooth for LDAC (24bit/96kHz), APTX/HD,SBC,AAC
Note that the analog outputs offer two settings:
  • Preamp volume control, with output up to 5.2Vrms (XLR) or 2.5Vrms (RCA) at 0dBFS.
  • Fixed output (no volume control), with output of 4Vrmr (XLR) or 2Vrm (RCA) at 0dBFS.
Ok, time has come for measurements
SMSL D200 - Measurements (USB in - XLR Out)
As opposed to CD Players that I like to review, I'm not used to measure these high resolutions DACs. So I'll follow the lead of @amirm, as he did recently for the Fosi Q6, and will try to concur to his way of measuring, so you get pretty much the same information.
All measurements performed with an E1DA Cosmos ADCiso (grade O) set to mono mode (SNR >129dBA), and the Cosmos Scaler (100kohms from unbalanced input).
I did not succeed to completely get rid of some power supply related leakage, but it stayed very low (<-135dBr).
I upgraded to latest firmware but I did not see any differences in performances before and after.
The D200 outputs a high 5Vrms from the balanced output at 2 times less from RCA. The channel imbalance is a very low 0.01dB, which is very good.
This is the XLR output (Variable output -2dB) with 1kHz @0dBFS (so that is 4Vrms output):
Similar to the AP of @amirm, this is from 24bits/44.1kHz sampling rate, with 32k FFT and 4 averages (I can't do 3).
The two channels are shown but only one is evaluated in the dashboard, the other one has a THD+N of -115.7dB, so that's the same. It's a little better than the specs (-114dB) and the same as what SMSL exhibits on their website with couple of views from an Audio Precision.
By the way, this is a view of the same but with RCA outputs, since SMSL shows them too:
I measured precisely the same performances as them, which is good news. Also, due to the negligible variation between RCA and XLR, I'll continue this review from XLR outputs only.
These performances, on SINAD perspective, would put this DAC in the middle of the "Excellent" raking of @amirm.
[BEGIN EDIT]
@Rja4000 suggested I increased the gain at the input of the Cosmos Scaler in fear I'd bit hitting the noise floor of the Cosmos ADC, when measuring the DR. And indeed I got 2dB better DR when doing so.
So, on the Dynamic Range side, I got the below:
This is from 997Hz test tone with a CCIR weighting curve, as the AES now mandates. So, we get a DR of 119dB. This is very good. For the sake of comparison with measurements performed with the old A-weighted curve, I get 123.6dB, which nearly exactly what SMSL reports with 123.4dB.
[END EDIT]
Anyways for me who's used to measure CD players, that's crazy good, since this is 20dB better than CDA :)
Next is the bandwidth (48kHz sampling rate):
These two measurements concur with the published specs of the Rohm BD34352EKV DAC. No surprise here.
From what I can measure, the IMD performance is good:
And the jitter test is nailed:
I forgot the Multitone test (48kHz sampling rate):
Despite that spike at 150Hz (an interaction from mains (50Hz)), we have 20bits or more of distortion free range.
EDIT: The below is from the WAV file that @amirm shared some time ago, and is the multitone test from the Audio Precision (192kHz sampling rate). So that helps to compare with the other reviews here. Same results, basically:
For compatibility with Stereophile measurements, here is the 50 Hz spectra under 640 ohm load (not 600, sorry, I can't), Linear Frequency Scale:
This is good but we have a little more low level random noise with low frequencies tones, as we've seen especially with the Multitone test. This is nevertheless very good.
Oh yes, and the THD+N ratio vs level:
This is an excellent result, really. We see a some distortion at low and high frequencies but the THD+N ranges from -111dBr to -102dBr meaning a very low level of ultrasonic noise (since distorsion and noise are accounted for up to 90kHz in that test).
And here comes the interesting par of being able to change the oversampling factor of the delta-sigma modulator. Maybe you wonder what is "Sound Color #3" I put on the graph. Well, that was how SMLS named the different settings of the ΔΣ Modulator (from Sound Color #1 to #4) in their original firmware. After I updated the firmware, the different setup are aligned with the doc of the Rohm DAC, and the SOUND COLOR shows the below:
  • LOW OSR + HPC ON
  • LOW OSR + HPC OFF
  • HIGH OSR + HPC ON
  • LOW OSR + HPC OFF
Let me decipher all of that:
  • OSR stands for OversSampling Rate, and my guess is LOW is for 16x and HIGH is for 32x oversampling rate of the ΔΣ Modulator.
  • HPC stands for High Precision Calculation, and this is related to the mathematical precision of the computation, draining more current when in HIGH mode.
You can find all of that explained in the datasheet of the Rohm BD34352EKV DAC, and they refer to it as "Sound Settings".
Let me further describe what that is. Look at the block diagram of the DAC:
You can see the oversampling filter, that can be set to sharp or slow, and that is the one adding more samples in between original samples, and performing the anti-imaging function, by filtering everything above Fs/2.
Next, there is the Delta-Sigma modulator that reduces the bit-depth to the one required for the final conversion. This is done again with an oversampling of a set order (generally 4, or more). To reduce the PCM stream from 24 bits, to 4 or 5 bits (I don't know here) required by the Delta-Sigma converter, there's a need to keep safe the original SNR. Since we loose roughly 6dB every bit we drop, it is necessary to compensate that loss by a combination of oversampling and noise shaping. These two mechanisms together allow the engineers to reject the quantization noise (when reducing the bit depth) far away in frequency.
And voilà, the idea of Rohm, offered to us to play with in the SMSL D200, is to reject even further the quantization noise of the noise shaper. Of course, this require more computing power, and has some drawbacks too, as I've seen and will show you.
The below shows a 1kHz sine @0dBFS played either with LOW or HIGH oversampling of the ΔΣ Modulator:
This linear frequency scale view goes up to 80kHz. You can see the advantage of the low ultrasonic noise with a higher oversampling rate. The green trace is with the ΔΣ Modulator oversampling rate set at LOW. You can appreciate the building of the noise that is rejected here in this mode, by the noise shaper.
This is the reason why the THD+N vs freq measurement was so good despite me including all noise up to 90kHz, like @amirm usually do. But with the ΔΣ Modulator oversampling set to low, I assure you the performance would have been much lower, because of all the noise rejected from 35kHz by the noise shaper.
Ok, you thought this is a little too complex? So let me add a bit more :p Have a look at the very interesting and busy graph below, based on white noise long time averaging:
This is an even wider view, up to 300kHz. I played with the FIR Oversampling Filter (Sharp and Low) and the ΔΣ Modulator oversampling rate too.
With that view, you can appreciate that:
  • The slow filter (LOW) is fully active at only 44kHz and exhibits ringing, ie it filters less of the aliases of the conversion
  • The sharp filter (SHARP) is fully active ad 24kHz and filters way better the aliases.
  • The effect of decreasing the oversampling rate of the ΔΣ Modulator generates noise being built as soon as 35kHz and going up to -60dB at 165kHz.
The dark blue trace is the SHARP FIR and the HIGH ΔΣ Modulator oversampling rate, and I like it :)
Note that there is a "NO FILTER" option, but there's a problem with this mode, at least with my early device. I saw a significant decrease of level and high distortion. There's probably something wrong, but at least I saw it indeed does not filter at all, plenty of unwanted aliases are created out of the audio band, meaning it mimics a Non Oversampling DAC (which is bad, don't use that), but since there's still a ΔΣ Modulator that must oversample, I see the effect of that oversampling but I can't understand it. So as long as I'm not 100% sure of what I measure, I'll refrain to publish, but anyways don't go NOS mode with a DAC, please pretty please.
SMSL D200 - Measurements (SPDIF in - XLR Out)
I briefly checked the quality of the SPDIF optical input (16bits only), to find excellent performances. But I saw additional low level random noise at the foot of the fundamental, when feeding it with 16bits stream from a CD Player. It shows better itself when performing a jitter test (16bits/44.1kHz):
This would have been a perfect trace without the little random noise at the foot of the main tone. It is negligible below -120dBr, though.
EDIT: I just did the same test from a Pioneer PD-D9 and the result id better:
The noise is almost at the foot of the fundamental. I don't why it was higher with the SMSL PL150, but I'll check that when time allows (I suspect a problem with the Coax cable I used with the SMSL).
And that being said, this is a very high precision DAC anyways.
Best proof is one of my favorite measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal
Without surprise, this is one of the best trace I've seen, nearly 0 noise comes in the way, it is very close to the digital data.
Theoretically we should get a square at this lowest level of the PCM 16bits format, and we don't because of the limited bandwidth (Gibbs phenomenon). The ringing tells us that the reconstruction filter is symmetrical.
By the way, since I'm here, at fixed output level, that is 4Vrms XLR (-2dB compared to max possible), let's see how this DAC resists my usual intersamples over test:
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
D200 from PL150 (CD player)-68.5dB-56.9dB-39.1dB
SMSL PL150-52.1dB-30.8dB-19.2dB
Well, we get some headroom but not much. If I go to "preamp mode" and lower the volume by a lot more (eg -6db) I don't get more headroom, and that is because the volume control is not done in digital domain, prior to conversion, but post conversion by an IC that attenuates the output voltage (digitally calculated attenuation).
Volume Control
Following a conversation started here about the volume knob of the D200, I edit the review to add couple of information, from the feedback of @Panelhead and @Roland68.
The volume control is provided, post DAC, by a digitally controlled analog attenuation chip (NJU72315). This means there should be a difference in measured performances between send an attenuated digital signal to the DAC, or attenuating by the same level via the front volume know.
And indeed, this is a comparison between the two for a -6dBFS output (D200 set at 5Vrms output, meaning it will be reduce to 2.5Vrms):
The digitally attenuated volume decreased the SINAD by nearly 3dB, while it remained the same when attenuating with the Volume knob
And now the same test but at -12dB attenuation:
The difference is now significative. In tems of SINAD and therefore ENOB, we loose more than 1bit of resolution when decreasing the output digitally, compared to using the volume knob. It is good to see that a -12dB, you get the exact same performance (SINAD >115dB) than at full scale.
At -24dB, there is a now a significant difference in SINAD of near 10dB:
Digital attenuation (left) gets us to below CD Audio resolution, while volume attenuation by the same -24dB keeps us way above CDA, on a SINAD perspective (97dB vs 106.3dB).
In addition, I did not see any trace of channel imbalance from 0dB to -32dB (the two channels matched at 0.00dB).
I also thought about another way to understand the performance of the volume control, as I wanted to compare to more standard digital attenuation pre-conversion.
For those, I used a Topping D50III, kind of a reference, which offers digital volume control. And I compared with the D200 at different levels of attenuation: I sent a constant 1kHz @0dBFS, and then attenuated the output using their respective volume controls. I then captured key elements of performances, the THD+N, THD and ENOB:
As you can see, if the Topping does better than the D200 in pure performances above -10dB, the D200 leads from -10dB and below.
This means that the D200 is recommended if your plan to use it as a preamp. Its volume control is not as advanced as the one of an RME ADI-2 DAC for instance, but it is nice to see that you can keep a high level of precision even with significant attenuation. It is also good to confirm that digital volume attenuation, pre-conversion, can be beaten by a well-designed volume IC.
All the above means that the volume control of the D200 is very precise and ensures minimum loss. It is to be preferred if you need to attenuate the output of this DAC.
Note that the DAC will recall the last attenuation at start up.
Sorry, I know it's a lot of information to digest, it was for me too and it's not finished!
But from what I gathered so far, I think this DAC is a high performing one, and the possibility to play with a selection of FIR filters and ΔΣ Modulator oversampling rate is cool, even if I can't hear a difference.
And for those of you worried about a noise shaper generating too much noise, too close from the audio band... well, you have a winner here! @Scytales if you read me ;)
The little random noise I've seen from a CD Player, as a source, is of no concern.
I hope you enjoyed the review and have a nice weekend!
How it sound, what matters to me is how it sounds and not how it measured?
It's good that these things are unrelated.
I hope you understand the sarcasm.
Any DAC that has its own "sound or sound signature" must be considered technically defective.
Most people don't even understand what a DAC's job is.
A DAC's only job is to convert existing data from digital to analog, period, end of story! Nothing more.
These are absolute and precise data; there's no room for interpretation.
If two different DACs produce different results from the same data, whether measured or audible, then either one of the DACs is defective, or both.
Or would you want a device that arbitrarily alters the music source material without your consent, without you knowing how or why?
SMSL released a firmware update V1.04 for the D200 today that changes the "Mute" function of the volume control to completely silent operation.
Previously, when the volume was reduced to mute using the rotary knob or remote control, the music was still faintly audible, as is often the case with potentiometers. Only pressing the mute button on the remote control completely silenced the output.
With this update, the sound is now completely muted when the volume control reaches "Mute."
The update can be easily installed from any computer, as only two files need to be copied to the D200's internal drive.
D200 MCU V1.04
Many thanks to @Kitty (S.M.S.L Marketing) for handling this update so quickly and efficiently.
D200 MCU V1.04
I'm not sure that this will matter to those that use the D200 only as a DAC... However, there is a problem with the firmware installation instructions .TXT file in the download for those who don't read the language it is written in... I am an English speaker and I cannot translate this... Luckily, I have the update instructions from the previous firmware update to follow (I am presuming this procedure is the same) and will attach those English language instructions.
The update instructions are the same; for other languages, simply upload the PDF document to Google Translate and have it translated.
Since the change only affects the volume control, the update will not work in DAC mode.
It's not supposed to work like that. A possessed by demons Professor of sour cabbage soup Сoсonus, will be dissatisfied.
It is perfectly clear that in V1.04 they simply tied the relay trigger to the -60 mark.
Why resort to distorting my nickname and using such undignified language? Operate with facts instead of your bad mood. And where exactly did I complain before the firmware update? I was perfectly fine with a simple poke at the 'Mute' button on the remote — an action that is clear to everyone.
But surely, you won't start acting like me and other adequate users now, right? I am convinced you’ll continue clicking all the way down to -60 every single time, just to reassure yourself of your 'victory' over the 'bug.' Well, to each his own... sounds like a quite fascinating way to spend your time! ))
Is there any downside to installing the V1.04 firmware?
If this version is not installed, will this create a problem with potential future firmware installations? ...
I have no need for volume control/mute in my playback scenario (DAC only) so, see no reason to install V1.04... The D200 has been installed in my playback system for a few months with V1.02 firmware...
Also, I suggest that the OP review the labeling of graphical information for accuracy... I have noticed mislabeling of trace data in the filter results...
New table, this time with unbalanced outputs, and I added the SMSL PS200 to the picture, again using the front knob and when attenuating in digital domain, to show the difference.
The volume control of the D200 really fails these tests. A constant H2 has killed nearly all measurements below 0dB, strange. When attenuating in digital domain, I get better results, so that's the opposite compared to balanced outputs. This DAC has been obviously designed for balanced output.
The PL200 got very good results when using the front knob, well done for a device that intends to be a CD player before anything else.
The D50III is the star when using RCA outputs, its volume control obviously attenuates in digital domain since I got the same results twice:
Conclusion: never take anything for granted, trust but verify ;)
Superduper thank you! Just what I was looking for.
Was able to pull the trigger on the D200 just now, yes! Got a great deal from the Aoshida store on AliExpress, after anniversary sale and coupon and coins, came to just $225. That's a nice price for something with a fancy enclosure. I'm psyched to test out DSD Direct performance, supposed to be bit perfect unlike almost all other implementations. Now just have to wait for its long journey from China.
"I also have a D200 DAC, which I connect to my Pathos Twin Towers amplifier via XLR. What I would like to know is whether using the DAC’s volume control at -2 dB or using it in fixed DAC mode (without volume control) would provide the best performance. I’ve read up on the subject, but I’m a bit confused."
That doesn't matter with the D200, since the volume is controlled analogously.
What you're referring to is only relevant with digital volume control via the DAC chip's DSP, which isn't the case here.
You can simply use the fixed DAC mode (without volume control).
D200'de bu önemli değil, çünkü ses seviyesi analog olarak kontrol ediliyor.
Bahsettiğiniz şey, yalnızca DAC çipinin DSP'si aracılığıyla yapılan dijital ses kontrolü için geçerlidir, ki burada durum böyle değil.
İsterseniz sabit DAC modunu (ses kontrolü olmadan) kullanabilirsiniz.
Thank you for information.
That tube amp will be the limiting factor concerning noise and THD - by about one to three orders of magnitude. So the DAC performance is pretty much irrelevant in this case.
You should check that you don't overdrive the input of the amp which causes distortion. Sadly, the manufacturer doesn't even mention the input sensitivity of the Twin Towers as far as I could see, so you may need to ask their support for the data.
This land yet?
This land yet?
Yeah, it actually only took a week to get to me. It's quite beautiful:
Using as DAC only at max volume. Mostly listened to CDs with optical input so far and it sounds quite wonderful. Subjectively getting lots of definition and clarity, which is quite nice. Only had one day hooking up the laptop for DSD, it did seem to sound a little different from PCM. It's mostly just peace of mind that this DAC does DSD right, and that it looks so nice. But I think DSD playback has less edge to it, which may be perceived as warmer and more analogue, depending on preference. Need some more time with it, but those are initial subjective impressions.
If you no longer need the additional inputs, you could remove your Pre90/Ext90 from the setup, as the D200 has both a very good analog and channel-matched volume control (Muse) and a very good output buffer, each implemented in dual mono – everything that makes a good preamplifier.
I do need the inputs though, I have a turntable and cassette player, plus a 2nd CD player that has XLR outputs, the Chinese behemoth. Shame to waste such a nice feature on the D200, but oh well. Source wise, I live the road of excess.
Nice! I've got a Pre90 as well, love it. If you don't mind a weird question, how long is the USB cable that's included with the D200?
