SMSL D200 DAC Review
Rate this DAC
  • Terrible (*)
    Votes: 3 4.9%
  • Mediocre (**)
    Votes: 1 1.6%
  • Good (***)
    Votes: 11 18.0%
  • Excellent (****)
    Votes: 46 75.4%
Nice! I've got a Pre90 as well, love it. If you don't mind a weird question, how long is the USB cable that's included with the D200?
Approximately 1 meter long, maybe a few centimeters shorter.
If you need a longer one, make sure it's a genuine USB 2.0 cable, even if the DAC has a USB-C connector. USB 3.x and 4.x cables can cause problems due to the integrated circuits.
I didn't know that, thanks! 1 meter will be fine.
By the way, here are some tests using the volume knob vs attenuating in digital domain.
When attenuating the digital input by few dBs, we inevitably reduce the resolution of the DAC (say the SINAD) by the same. When using a volume control post-DAC, this might not be the case, so let's try to compare what the D200 can achieve.
First, this a 1kHz @0dBFS (Full Scale) when the D200 is set to its max output, and that is 5Vrms (balanced outputs):
Unfortunately, at this high 5Vrms output, I can't reduce the headroom of my ADC for better precision (it is preceded by a scaler, of which next step is +6dB), meaning the D200 should achieve 19bits without that measurement limitation.
Now, if I reduce the volume by -1.5dB, I get 4.2Vrms output, and so I can increase the gain of my scaler to get the ADC in a its highest precision range:
Let's compare if I send a digital signal attenuated by -1.5dB and let the Volume at 0dB:
This exactly the same result.
Now, let's do the same at higher attenuation, for instance -6dB, which brings the output down to 2.5Vrms. The below is the comparison between doing it in digital domain (left view) versus with volume control (which acts after the DAC, as explained before):
This time we have a difference. Decreasing the digital volume slightly decreased the SINAD by nearly 3dB while it remained the same when attenuating with the Volume knob.
Let's try lower, @-12dB, therefore 1.25Vrms output:
The difference is now significative. In tems of SINAD and therefore ENOB, we loose more than 1bit of resolution when decreasing the output digitally, compared to using the volume knob. This means that the volume control of the D200 is very precise and ensures minimum loss. It is to be preferred if you need to attenuate the output of this DAC.
Any idea what the balanced output impedance is?
Yeah, it actually only took a week to get to me. It's quite beautiful:
Using as DAC only at max volume. Mostly listened to CDs with optical input so far and it sounds quite wonderful. Subjectively getting lots of definition and clarity, which is quite nice. Only had one day hooking up the laptop for DSD, it did seem to sound a little different from PCM. It's mostly just peace of mind that this DAC does DSD right, and that it looks so nice. But I think DSD playback has less edge to it, which may be perceived as warmer and more analogue, depending on preference. Need some more time with it, but those are initial subjective impressions.
Sounds like you have a winner so far. Have you been able to play both DSD and PCM through Foobar2000 on your laptop with the SMSL driver successfully?
Yes I played both DSD and PCM successfully on Foobar2000. No trouble at all to get it working, nice display of proper format and rate, though I think it was just DSD64 I played, and mostly redbook. Everything sounds fantastic, very pleased with this DAC.
Design is probably the best thing about these Chinese things, also measurements on the docs, but the joy ends as soon as you start listening to them : )
Sorry, but you just registered and already have three posts with such audiophile nonsense?
I think you're lost and just here to troll.
In any case, with just three posts you've managed to embarrass yourself.
Hi-end version of the d200 is coming. Based on the newest ROHM chips (BD34302EKV) and the NJU72315s.
€ 1.799,95
It will be interesting how the S.M.S.L. VMV D3R DAC implements a pair of BD34302EKV chipsets to imbue/translate a tangibly audible difference in comparison to the D200... It seems to target FOMO regarding iterative DSD512 encodings and DoP support of iterative DSD512 encodings (Both being modulated from lower sample-rate encodings) in a stylish package with more attention to platform power architecture to justify the price of admission... (Don't count me-in as a iterative DSD512 believer)
I know very well how devices on chips work where "volume control is achieved via resistors/voltage dividers"
I have several such devices, in addition to the D200 - two DACs, and two pre-amplifiers. For everyone, at the minimum value there is a complete absence of signal.
Let me repeat - the D200 has a very serious schematic or software defect.
On another forum, the owner of a D200 confirmed that he had the same problem. Both RCA output and XLR output. The firmware is also the latest.
upd
I'm not interested in the Mute button. I want the D200 to work properly, and not as crookedly screwed up in SMSL.
Are you running 2x D200s simultaneously?
