- Joined
- Nov 23, 2020
- Messages
- 182
- Likes
- 130
https://www.l7audiolab.com/f/remeasure-smsl-d1se/ Wolf remeasured it. Seems like they got rid of the jitter. I wonder if they got rid of the IMD hump too.
See first review here: https://www.l7audiolab.com/f/smsl-vmv-d1se-dac/@WolfX-700, did you check if the SMSL VMV D1Se still has the 3rd harmonic distortion issue detected in m500 and su-9?
Thanks, I can't chinese, therefore I wasn't there.See first review here: https://www.l7audiolab.com/f/smsl-vmv-d1se-dac/
the noisy channel M500 and SU9 bug from ASR has not been found/produced in this D1SE.
Based on purely measurements the topping d90se is a tack better but you're asking SQ wise? God knows it ...I wonder how the SMSL VMV D1se will compare to the Topping D90se in actual use SQ wise?
Goldensound has a review of the D1SE forthcoming. In this review of the Ares II, he says the Ares II and the D1SE are his current choices for best DAC's less than $1k. The Ares II being a little better for the tonality of acoustic instruments and vocals and the D1SE better for electronic music, low end micro dynamics. He says it's more neutral, a little less analytical than a D90. Anyways, I'll look forward to his review which should include measurments -Which one has the best sound, D1, D1SE, Topping d90se?
It's all beyond a audability.Which one has the best sound, D1, D1SE, Topping d90se?
If you are using such a dac, hopfully you aren't using bluetooth at all.No Ldac in the bluetooth, that's unacceptable for a such expensive dac.
Bluetooth can be quite practical to hook a cellphone quickly and ldac preserves the audio to a very acceptable level. The price of this device is high enough to demand the bluetooth to be good instead of half-assed.If you are using such a dac, hopfully you aren't using bluetooth at all.
That is impossible.And after a week, i have replaced the factory fuse with SR Orange - The improvements are very noticeable especially in music details and instrument separations. And there is also a widen background staging.
The power of the mind and sighted bias is strong in this one*snip*
