kazuviking
- Joined
- Sep 5, 2022
- Messages
- 93
- Likes
- 63
Its like i'm destined to have issues with this dac. The rail splitter is already failing after TWO AND HALF MONTHS. Time to DIY my own rail splitter psu that wont die this fast.
Can you elaborate? What are the symptoms/problems? If it is failing, why not exchange it under warranty?Its like i'm destined to have issues with this dac. The rail splitter is already failing after TWO AND HALF MONTHS. Time to DIY my own rail splitter psu that wont die this fast.
Have you checked what exactly isn't working?When connected to an amplifier, only one channel works on the DAC. One speaker doesn't work. Has anyone encountered this problem?
If you only swapped the cables on the D1 connector, then unfortunately you probably got a defective one. That's a real shame.I swapped the cables. Now, the speaker that worked doesn't work, and the one that didn't work now works.
I have another pair of RCA cables and the problem reoccurs with them.If you only swapped the cables on the D1 connector, then unfortunately you probably got a defective one. That's a real shame.
Then you'll have to contact the retailer so they can exchange or replace it.
Unfortunately, the test already confirmed that.I have another pair of RCA cables and the problem reoccurs with them.
Thanks for the advice.Unfortunately, the test already confirmed that.
This allowed me to rule out that the problem was with your RCA cables or the amplifier.
I'm sorry for you; I hope you can sort this out with the seller.
Costs way more to send it to to china than diying my own psu.not exchange it under warranty?
In the SU-1 thread you'll find information on high-quality DC/DC replacement modules for the SU-1/D1/C100, which are also very low-noise.Costs way more to send it to to china than diying my own psu.
Welcome to the forum, it's great that you've registered.Created an account finally, after being a silent reader for a while on ASR.
Considering the insignificant difference in pricing between the SU-1 and D1, and considering both seem to perform good enough that my human ears won't have much chance of hearing a difference, can I just choose either of them based on price or availability and be happy with it?
Or are there some actual differences to consider for my decision?
I had previously wished to "check out ROHM signature" but I suppose there isn't much of a signature to be had with a well performing DAC
Thanks for the warm welcome! Also, for the super quick replyWelcome to the forum, it's great that you've registered.
I have both, but I prefer listening with the D1. It's even outperformed my DO400 in the long run.
The D1 is also the latest development in a series of these small DACs—SU-1, C100, PS200—so you can assume that a bit more experience has gone into its design. The D1 is also a little larger and not as densely packed, which I prefer.
But ultimately, it's your decision.
If you get the SU-1 you will forever wonder if the D1 might have been better. But if you get the D1, in worst case scenario you will get the same performance, so no future worries.Thanks for the warm welcome! Also, for the super quick reply
Both the D1 and the SU-1 are available for almost the same price to me, both with similar enough shipping times (basically before vs after the apporaching weekend). Tho the SU-1 could be had for less because it's available used. Planning to use whatever I get with the Fosi V3 Monos sitting on my desk and the P4 that should be arriving sometime later today. Decisions to be made...
You don't explain why you prefer listening with the D1.Welcome to the forum, it's great that you've registered.
I don't have to, I just noticed it.You don't explain why you prefer listening with the D1.
