So, if a device simply has a codec and works perfectly, then for YOU it is equivalent to the sound quality of the best measured DAC?..Those types of comments just perpetuate myths about audio, nothing personal.
JSmith
JSmith
Pssst!So, if a device simply has a codec and works perfectly, then for YOU it is equivalent to the sound quality of the best measured DAC?..
www.audiosciencereview.com
Your bog standard OPA1612 and OPA1611 i think. I highly doubt its NE5532/34 as it requires some crazy feedback and layout to achieve this kind of distortion.can anyone confirm which opamps are used in D1?
I would assume they're NE5532s or something cheaper, since it's ROHM's standard layout based on the NE5532, and the measured values are in the same range as the evaluation board.Your bog standard OPA1612 and OPA1611 i think. I highly doubt its NE5532/34 as it requires some crazy feedback and layout to achieve this kind of distortion.
And in what cases do they erase the markings on operational amplifiers? Does this happen anywhere else, except among Chinese high-tech swindlers?..I would assume they're NE5532s or something cheaper, since it's ROHM's standard layout based on the NE5532, and the measured values are in the same range as the evaluation board.
Otherwise, they wouldn't have ground down the op amps.
It could even be an op amp that's not from the usual audio range.
Why do you speak of high-tech fraudsters? That would also apply to many American and European manufacturers, not just those in the audio industry.And in what cases do they erase the markings on operational amplifiers? Does this happen anywhere else, except among Chinese high-tech swindlers?..
SMSL usually grinds down most of their opamps so it can be anything really.Otherwise, they wouldn't have ground down the op amps.
"'High-tech' here turned out to be merely a translation difficulty. Of course, this refers to cases in the everyday Chinese audio industry, rather than in rocket and space technology.Why do you speak of high-tech fraudsters? That would also apply to many American and European manufacturers, not just those in the audio industry.
In most cases, it's simply a matter of no one knowing which components are being used, partly to secure competitive advantages and knowledge. This was already done over 40 years ago, for example, with logic ICs or memory chips. Nothing new and nothing wrong.
This is what reviewers tells you a DAC does:DACs have a sound that varies from model to model.
Meanwhile, THIS Chinese manufacturer is experiencing true happiness, allowing itself to openly and defiantly lead the hopeful user by the nose.Ne5532 is actually an excellent opamp.
I could be more than happy if smsl uses original ne5532 and not some cheap jrc ones that are very common in Japanese mass market equipment.
But all DACs that have a "sound" must be technically considered defective.DACs have a sound that varies from model to model. Ask anyone who has been involved in music production over the last 30 years or so. Even the old first generation2018 bit ADAT and Digidesign converters measured better than the theoretical 16 bit converters, but they were pretty bad sounding. Over the years companies like Apogee, Avid, Yamaha, Lynx, dCS, Tascam, Alesis, Radar, and bunch of others have constantly worked on better sounding products, used newer and better DAC chips by companies like AKM, Burr Brown, Analog Devices, Philips, Sony, Cirrus Logic and things did audibly improve. All those improvements would probably be classified by the gatekeepers on this board as below the threshold of human perception, but they did make a difference to the people who used them for living.
Personally I started out on the first gen Akai hard disk recorders in the early 90's, then had a 24 track ADAT studio that went from the original black face models to the second gen models. Then I went to work for one of the biggest sound reinforcement and AV integrations companies and had my hands and ears on a ton of digital gear including DSP processors, digital consoles and other digital AV gear. It's not hard to tell the original Yamaha M7 mixer from a more modern Yamaha digital mixer or a DiGiCo mixer from a Studer or SSL product. Same for the older DSP processors and the newer ones. The quality of AD and DA converters is not hard to discern with no processing applied.
I already wrote that."'High-tech' here turned out to be merely a translation difficulty. Of course, this refers to cases in the everyday Chinese audio industry, rather than in rocket and space technology.
And yet, does something similar occur in comparable branded products from American and European manufacturers?
I also replied to you that I am not interested in ALL manufacturers, but exclusively in well-known American and European ones in the branded Hi-Fi and Hi-End sector. But you either missed this or ignored it ((. So why make such a statement if you cannot specifically confirm it?I already wrote that.
You can find obscured/illegible electronic components from almost all manufacturers, not just in the audio sector. This is a very effective tool against product piracy, technology theft, and counterfeiting. And as I said, it's been going on for decades and isn't illegal.
And as long as the manufacturer doesn't advertise using a specific component, it can't be fraud.
Whatever the difference is between the different converters, it must be measurable because typically different people acting independently all have similar comments about specific devices. It's a question of measuring the right aspects of the converters. For example I have not seen anyone in this thread commenting about the D1 being the opposite of bass strong. It's either that or "I can't hear any difference". Makes one think, there should be something about the way it reproduces the low frequencies in relation to the treble that makes is sound a certain way to some listeners. I heard smooth treble as compared to the other two CS43131 based DACs I had on hand right away. And went on record that the low mids and bass in the D1 have a quality to them that is not present in the other two. I only read through the rest of the thread later and noticed that some posters have a similar impression.But all DACs that have a "sound" must be technically considered defective.
Most people aren't even aware of the purpose of a DAC, and it has nothing to do with audio. Most DACs are used in industry, measurement technology, automotive, avionics, science, etc.
DACs and ADCs only have the task of converting existing data from digital to analog, or vice versa. This is absolute and precise data; there's no room for interpretation.
If two different DACs produce different results from the same data, then either one or both DACs are defective.
The diagram posted by @Svend P illustrates this quite well.
If a DAC audibly deviates from the original music signal, then it has altered it and failed in its intended purpose.
By the way, hundreds of our blind tests have always yielded the same result. When the testers could no longer see the devices, the audible differences disappeared in most cases. However, the actual audible differences were clearly measurable.
Strange, isn't it?
Offenbar wollen Sie die Antwort nicht verstehen. Ja, selbst namhafte amerikanische und europäische Audiohersteller machen das. Ich habe in den letzten 35 Jahren einige Tausend solcher Geräte von innen gesehen. Selbst bei einfachen Dingen wie Netzfiltern wurden die Komponenten verdeckt, um einen Nachbau zu erschweren.Ich habe Ihnen auch geantwortet, dass mich nicht ALLE Hersteller interessieren, sondern ausschließlich namhafte amerikanische und europäische im Marken-HiFi- und Hi-End-Bereich. Das haben Sie aber entweder übersehen oder ignoriert ((. Warum also eine solche Aussage, wenn Sie es nicht konkret bestätigen können?
Please, elaborate... we want to know what you know.It's a question of measuring the right aspects of the converters
A blind test is only stressful for those who think they need to hear a difference.Whatever the difference is between the different converters, it must be measurable because typically different people acting independently all have similar comments about specific devices. It's a question of measuring the right aspects of the converters. For example I have not seen anyone in this thread commenting about the D1 being the opposite of bass strong. It's either that or "I can't hear any difference". Makes one think, there should be something about the way it reproduces the low frequencies in relation to the treble that makes is sound a certain way to some listeners. I heard smooth treble as compared to the other two CS43131 based DACs I had on hand right away. And went on record that the low mids and bass in the D1 have a quality to them that is not present in the other two. I only read through the rest of the thread later and noticed that some posters have a similar impression.
Blind tests have their own problems. I participated in a few and have my own suspicions as to why they become so difficult for the participants. I don't know if there was a scientific study that looked at audio perception under different conditions, but there should be.
