can you share some more details about the downsides and USB issue?Yeah if i ignore every single downside and usb not working properly.
i'm just looking for a small (size wise) and cheap DAC with USB input and a separate power inputWhat is the attraction of this ROHM chip DAC?
There are a few excellent measuring cheap DACs available but I am seeing more and more inclining to this one.
Is it because a few expensive DACs had RPHM chips only until now?
*** Just curious.
ROHM chip DAC
Cool.Personally, having tried both ESS and AKM chips, which, to be honest, even when they measured close to perfect, didn't sound that "musical" (yes, I know - but the SND etc etc), I wanted to try something with another chip.....Is it perfect? No idea, not dones any measurements, do I like the sound, yes.
You can’t dismiss measurements unless you pass a volume matched blind test. If both dacs have a noise floor and distortion below –100 db, a flat frequency response, and a reconstruction filter with acceptable attenuation, and you can still reliably distinguish between them in a volume matched blind test, only then can your evaluations be considered free of cognitive bias.Personally, having tried both ESS and AKM chips, which, to be honest, even when they measured close to perfect, didn't sound that "musical" (yes, I know - but the SND etc etc), I wanted to try something with another chip.....Is it perfect? No idea, not dones any measurements, do I like the sound, yes.
You can't blame measurements until you pass a volume matched blind test.
That's the only way to overcome our cognitive biases.
Unfortunately, most of us are here because we’re fed up with people spreading their delusions and confirmation biases as if they were wisdom. We want to keep this place free of irrationality. Maybe what you’re saying is true wisdom, but around here we tend to ask for proof or at least substantial reasoning for why you think that way.Was waiting, yet again, for someone with this sort of response....outstanding! (cus, being 3 years old, never thought about volume matching and voltage...you know, that's for the grown ups in the room....and stuff).
The uC connector is so lose that the stock cable just dangles inside but SPDIF is so god damn tight that i barely could unplug the cable. The power button does absolutely nothing. After installing the SMSL driver it only works if i use an OTG cable for some reason.can you share some more details about the downsides and USB issue?
Funny enough, mine d1 works like having trigger function. I connect the d1 to my raspberry pi 5 by usb c, turning on the raspberry pi 5 triggers the d1 to turn on automatically and powering off the raspberry pi 5 powers off the d1. Works like a charm, even though I am not sure thats actually the original design featureI just received a D1 from the latest batch with the shortened internal springs. The sensors rely on harder pressing...but obviously too hard to work [it did work occasionally].
Can't switch it on anymore - any recommendations?...see video:
The mechanism, is, with all respect, pretty bad.I think that the touch action cannot be detected when your hand is touching the D1 case. I think that it will work if you remove your hand from the D1 case and touch only the touch button.
Couldn't use just one finger?.. ((The mechanism, is, with all respect, pretty bad.
I could use my happy finger...Couldn't use just one finger?.. ((
My "cognitive bias" expected a lean and harsh sound at this price
How did you manage to turn it on anyway?..As to the D1, this little rascal sounds really good with my stereo system. My "cognitive bias" expected a lean and harsh sound at this price. Somebody must have switched it off. How could we properly evaluate sound quality before measurements are being performed?
