Thanks for this update. This business with the filter settings seems sort of bumbling and comic because it never seemed to be correctly documented and yet also never seemed to matter at all.General information for all:
The Probable Corrected List of the ESS Filters
The reality for your D6S likely looks like this:
- FL1 (Incorrect): Labeled as "Minimum Phase", but is actually Minimum Phase Slow (ESS #8).
- FL2 (Correct): Linear Phase Apodizing (ESS #2).
- FL3 (Correct): Linear Phase Fast (ESS #3).
- FL4 (Correct): Linear Phase Fast Low Ripple (ESS #4).
- FL5 (Correct): Linear Phase Slow (ESS #5).
- FL6 (Correct): Minimum Phase Fast (ESS #6).
- FL7 (Correct): Minimum Phase Slow (ESS #7).
the original ESS #1 filter is missing from the selection.
The ES9039 chip technically offers 8 different filters (ESS #1 through ESS #8). Since the SMSL D6S menu only provides 7 slots (FL1 to FL7), one filter had to be omitted.
SMSL decided to assign ESS #8 to the FL1 slot. As a result, the original ESS #1 ("Minimum Phase Fast Roll-off") is not available in the menu.
Does this matter?Not really, because:The filter FL6 (ESS #6) is also a "Minimum Phase Fast Roll-off". In terms of technical performance and sound characteristics, ESS #1 and ESS #6 are extremely similar. Both offer no pre-ringing, a sharp impulse response, and a steep roll-off.
If you are looking for the sound that the missing ESS #1 would have provided, simply use FL6. You aren't missing out on any specific sound signature; the labeling is just confusing.
Alrigthy?
But may I ask, just to keep the fun alive: what is your source for this probable, likely update info?
