nanook
Thanks a lot for confirmation @trungdtmc. So my measurement seems not to be flawed.
On both D-6s that I measured the left channel did show the THD-vs-level hump more pronounced than the right channel. I might just measure my third unit the next days to see if this is consistent across all three units.
I'm wondering why the DO400 (1x ES9039Pro) does not show this. The output of each of the stereo channels of the DO400 is the average of 4 DAC outputs of that 8-channel chip. In case the phenomenon is related to limit cycles in the SD-DACs that occur at this level, these limit-cycles would very likely be somewhat different on the 4 merged channels due to tolerances and noise. Each internal channel only contributes 1/4 of the amplitude, so this could provide ca. 12dB attenuation. compared to the D-6s.
If merging of several channels alleviates this hump, e.g. the SMSL RAW MDA-1 or DO100 Pro (2x ES9039q2m, but likely very similar analog stage) should show this hump at the same digital drive level, but ca. 6dB less pronounced.
I might as well try to dig deeper into the noise floor of the DO400 - perhaps a hump will then also become visible.
Any other "dual ES9039q2m" based DAC would be welcome to be measured.
