Superb, well done Amir. Thanks for the review and measurements.
Bluetooth 5.1
What about the Bluetooth input and this DAC? Are there any restrictions compared to the other inputs? I'm curious because I don't know Bluetooth and don't know anything about its signal quality regarding DACs.Is the Bluetooth receiver in the SMSL D-6 powerful enough? Is it sensitive in terms of signal strength?
Bluetooth in and balanced out? Is it working?
Those of you who have tested Bluetooth on your SMSL D-6, please tell us about your experiences. If it works well? Any problems?
Looking at this, what is said in the quote below. Is it good or not? :
Bluetooth 5.1
SMSL has equipped the D-6 with the latest Qualcomm QCC5125 chip, which offers high-resolution Bluetooth 5.1 reception capability, including support for aptX HD and LDAC codecs.
The D-6 joins SMSL's wide range of DACs, offering excellent performance for a contained price. It is equipped with two AKM AK4493S conversion chips and a second generation USB XMOS interface.
www.audiophonics.fr
What is:
high-resolution Bluetooth 5.1? That is, how high is high? I'm mostly curious about how good a signal you can get via Bluetooth these days.
Edit:
I found information about the quality of the signal via Bluetooth, see attached image and link. Good for Spotify anyway.
No support IOS, iPhone, together with aptX HD from what I could see but maybe there have been changes? I'm using Android so it's not something I'm worried about. Just wanted to mention it.
(I could be wrong about IOS and aptX HD)
Remote control:
Those of you who have an SMSL D-6, how do you think the remote control is? Easy to work with? Easy to change the volume? Have you tried plugging this DAC directly into a power amplifier and then changing the volume via SMSL D-6?Experiences with that?
