That is what I want to do too!I also use fixed full output, and feed it to the direct in of my power amp - through an external passive volume control.
What kind of passive preamp do you have?
It is just a dual potentiometer mounted in a box with RCA connectors - no electronics. This is what I bought, unfortunately NLA:That is what I want to do too!
Is this driver fix still working for you? Asking because my D6 has also started with the static/popping noise.Edit:
I deleted the ASIO driver, and replaced with the most recent one from the SMSL website -
Which meant that I had to re-do the "Streaming:Always On" fix (see post # 200 above), which I did.
So far all has been well, no pops or breakups.
Fingers crossed....
Yes, my D6 is working fine.Is this driver fix still working for you? Asking because my D6 has also started with the static/popping noise.
Hi which of of the DAC do you prefer? Does the DO100 sound warm like the D6? I hear the D6 sound warm?Just pulled the trigger on this DAC and am super excited! I already have a DO100 though, and despite this being an AKM DAC, not expecting much difference for redbook (SINAD is worse actually) but I got this for DSD processing, especially DSD Direct mode (PrD). Hopefully this will elevate the level of my DSD rips, but I won't know for sure until I try. Price was right, got it open box, so not much to lose. Will be using this in my big speaker rig where I do not use EQ or any correction, hoping for some nice detail and synergy. Will move the DO100 to my bedroom headphone rig, and convert DSD to PCM since I use EQ there. IME the ESS DAC does not decode DSD as well as AKM (clips on the original Thriller SACD, doesn't decode mym one DSD512 album). I so wanted a Topping E70 Velvet but lack of DSDD implementation was a deal breaker for me, for me it's a killer feature for AKM DACs. The D-6 looks more velvety to me, happy to find out that what I want is actually available for cheap.
No DAC sounds warm, lukewarm, or cold.Hi which of of the DAC do you prefer? Does the DO100 sound warm like the D6? I hear the D6 sound warm?
I don't want a bright/fatigue DAC
Congrats on getting this great DAC. Ignore the naysayers, this DAC is great for DSD upconversion.Hi which of of the DAC do you prefer? Does the DO100 sound warm like the D6? I hear the D6 sound warm?
They're both warm sounding, and non-fatiguing. But I prefer the D-6 for proper DSD support, and this extra sauce that's oh so yummy that they term Velvet Sound. It's buttery smooth yet very sparkly as well.Hi which of of the DAC do you prefer? Does the DO100 sound warm like the D6? I hear the D6 sound warm?
ThanksCongrats on getting this great DAC. Ignore the naysayers, this DAC is great for DSD upconversion.
I use it exclusively in DSD direct mode, that's the great advantage of AKM chips.
I had some trouble with it going to DSD 512 (DSD 256 was always solid), but this cleared that up:
Synapse _ Shop JDS LABS
Synapse is a UAC2 compliant galvanic isolator, built to eliminate ground loop noise without compromising USB sampling rates. Its ISOUSB211 enhances performance by cancelling USB signal loss and optimizing the USB timing diagram, while supplying super clean, transformer isolated power to your...jdslabs.com
YMMV...
Thanks. So the topping E70 velvet will have the velvet sound too?They're both warm sounding, and non-fatiguing. But I prefer the D-6 for proper DSD support, and this extra sauce that's oh so yummy that they term Velvet Sound. It's buttery smooth yet very sparkly as well.
Also the optical input on the DO100 is glitchy, I was using it to play CDs. So it's been relegated to headphone system duty, just BT input currently from my cell. Sounds very good to me but the D-6 is my main DAC. Tried to find a backup a little while back but was having trouble.
No sound signature to be found in the E70V: https://www.l7audiolab.com/f/topping-e70-v/So the topping E70 velvet will have the velvet sound too?
Thanks. So no difference in sound btw the E70 and E70V?No sound signature to be found in the E70V: https://www.l7audiolab.com/f/topping-e70-v/
Neither Velvet nor otherwise.
Input becomes output and that's it.
Correct.Thanks. So no difference in sound btw the E70 and E70V?
No sound signature on the D-6 either. Just plain, clean tap water.Also what about the SMSL D-6 having velvet sound?
"But I prefer the D-6 for proper DSD support, and this extra sauce that's oh so yummy that they term Velvet Sound"They're both warm sounding, and non-fatiguing. But I prefer the D-6 for proper DSD support, and this extra sauce that's oh so yummy that they term Velvet Sound. It's buttery smooth yet very sparkly as well.
ThanksCorrect.
Your music is what provides the taste.
Okay I may be biased since almost all my music is warm, especially classic rock. Only music I've heard that's cold is Bartok string quartets, and some recordings from Andrew Hill. Perhaps Schoenberg and Weber too, and Art Ensemble of Chicago, largely avant-garde stuff."But I prefer the D-6 for proper DSD support, and this extra sauce that's oh so yummy that they term Velvet Sound"
Thanks
