SMSL c200 + BEYERDYNAMIC DT 770 Pro 250 ohm LE - would it work?
PolishNewbie
Sorry to bother you guys, but I'm not sure if it would work... Like - okay I can plug them into because there is a interface for them - fine, but according to SMSL C200 Manual
I should put them in 32 ohm mode right? - because this is 32 ohm and above? Btw what you think about that setup? I use Tidal with max plan for FLAC Audio, play a bit of games and like to watch movies *Recently got my first qd oled monitor and now I fell like audio is not enough compare to my screen haha* I run atm Razer Blacksharks v2 heh
No such thing as 32ohm mode . That tells you what power it should put (Max) into that load . It does have gain selection . Try low gain first , if that maxes the volume dial , move to high gain .
Okay - my bad. But it should work? I'm about to buy it really soon + Slamming volume to max COULD destroy something?
Your ears maybe ? Start a low volume on the dial always and turn up .Also, play music before putting on your ears
Yeah that's for sure - I just heard from my dad who run 5.1 Tonsil speaker setup with technics eq, amp etc. That you never should volume max because something could break
if i got that kind of setup - i should run everything in pc on max volume and only on knob adjust volume right?
