I can't help but feel SMSL's amps are not of the same calibre as their DAC's, which are generally excellent.the subwoofer cutoff is also suspect
theres a difference in what they say in the manual vs. whats on their site
Thanks. Very usefull.BTL measurements added to the review. You do get almost 4 times the power but load dependency also increases causing serious frequency response errors.
This is a very practical feature, and I also have this question.the subwoofer cutoff is also suspect
Man I love you! A lot of people (well me lol) are looking for a small affordable Class D amps to power DIY subwoofers without the fuss of making a separate chamber for plate amps and this is a pretty serious candidate.BTL measurements added to the review. You do get almost 4 times the power but load dependency also increases causing serious frequency response errors.
More interested in AL200 which is brand new (and allows for a full screen off)SMSL's AO200 changed the amplifier chip from Infineon MA12070 to MA5332MS which is the same as A300 and released as AO200 MKll.
I hope that this product will also be measured soon.
Pretty useless for passive subwoofer use without phase/delay control.Thanks. Very usefull.
So, in short, BTL mode is perfect to power a Sub, and using 2 amps would allow driving both one Sub and a stereo pair of Main speakers to high level, especially if a cross over frequency around 75 Hz is what you need ?
(All that for under $400.)
OTNot to mention most people that are building passive subwoofers, are building large, high-output boxes, and will need more power than this...
Won't filter eat some of that performance?Would be nice to see Fosi or Aiyima release a TPA3255 implementation with a good PFFL (a’La 3e audio) and hi-pass/subwoofer management, and then we could get a 104 SINAD,
I really like the heavy duty binding posts. And for those of you needing subwoofer support, the filtered sub out and mains. It also includes Bluetooth functionality in addition to reading from a USB stick. With two inputs and a remote control, you are set for the modern audio systems of today.
Sub Out/Filtered Mains Output Measurements
Edit 2: here are the measurements of the sub output and mains set to filtered:
Yeah... 50Hz vs 80Hz. Fixed frequency and slope? No PEQ and delay adjustment at all? Borderline useless.the subwoofer cutoff is also suspect
