Hello everyone,
I’m new to the forum and I’m considering buying the SMSL AL400. The power output, feature set, and of course the compact design fit perfectly with my plan to finally replace the many separate components and large boxes currently in my living room.
I’m running a 2.1 system with Dynaudio compact speakers and an active subwoofer. So far, I’ve been driving the subwoofer via the preamp output of my NAD C352, using the low-level input. In that setup, the audio signal is processed inside the subwoofer itself.
The AL400 has a dedicated subwoofer output where crossover frequency and volume can be set.
My question is: What exactly does the menu item “Subwoofer LPF FC VOL” do? I would like the amplifier to simply output the signal on the subwoofer output up to the selected crossover frequency, and for it to be controlled normally by the main volume control together with the main speakers.
Thank you very much for your help!
