Smooth walls vs shelving, speaker / subs placement
john61ct
Looking for general acoustics advice on open LDK living room's listening area. ignore visual aesthetics and possible covering of the tiled floor for now, and assume in future DSP / DRC will be applied, at least below Schroeder...
The space is currently half full of cardboard boxes stacked on rolling bakers racks, there is no place to move the boxes to clear the space.
Total room ~15x30'
The listening floor area ~ 15'², only one side wall is drywall smooth, behind LPs is a hallway entrance and patio glass door opposite each other, then the kitchen / dining area.
I'm thinking best for the walls to be more symmetrical, so put half the racks along the left side to match the right?
The front wall is currently smooth, but as I can afford to I think I will go Ikea Kallax shelving floor to 9' ceiling to then reduce the volume taken up by the bakers racks along the walls. Cubbies mostly open, but some can get sliding cube inserts, doors or drawers, thin plywood or lighter materials.
What will this do as an acoustic backdrop, as opposed to smooth?
All speakers including subs will be sized < 13"³ to fit within the cubbies, at least for transport (semi-mobile sound system)
But in use if needed, they can be brought out into the room, stacked and/or on stands, all to be based on testing.
All feedback and constructive advice welcome...
