Small subwoofers
I built 2x 8" Dayton Ultimax subs for my 10'x10' (3m x 3m) office and put one under each side of my desk, powered by a Crown XLS 1500. They worked very well and dug deep, but output was limited more that I liked, which was a bit annoying for those times I wanted to rock out. Most of the time, however, they were sufficient for my desktop setup and normal volumes. After a year I built 2 more for the rear corners of the room (plus another Crown), which fully solved the output problem. With all 4 subs, I topped out around 100 dB. I didn't get compression there, but the Ultimax drivers started making a little bit of mechanical noise at the top sweep so I stopped.
The only reason I went with little 8" subs was for space, as it's hard to shove big subs in a small office. I've since moved to a different home, and and my new office is even smaller, but I'm still able to rock all 4 subs. I really like the flexibility of 4 smaller ones for desktop use, but I will caution that you need to be realistic about expectations.
Total cost with amps and all was $1553, so $263 each, back in 2022/2023.
Wow - these look quite amazing. Some of the best looking subs I have seen. It is just my opinion - sure there will be plenty that think otherwise (as usual).
They also seem very competent and flat so another plus. But 8" is not meant for headbanging unless there is even more of them.
They've improved the room fit feature a lot. You can connect a Umik to your phone and the results using the MMM mode are pretty good to my ear, especially given how easy it was. Definitely recommend trying it again when you get a chance. Cleans up the bass significantly.
OP was talking about the SVS App, while you're probably talking about the WiiM Home App?
I agree. You’ve created some very good-looking, aesthetically pleasing DIY subwoofers, @anotherhobby :)
Not looking for a big boom. I had 12' sub before and felt it was a bit much. So I sold it.
A 12-foot sub is rather large.
More seriously: properly set up, big sub(s) ≠ boomy. My music-only listening room is not much larger than yours and has concrete block walls (more boundary reinforcement). I use two 15" sealed subs and certainly wouldn't want significantly less low-frequency capability. No, I'm not a "bass head" and don't listen particularly loud.
Well, since I pitched in this thread because of the great looking and performing 8" subs, I might as well contribute more to the essence.
The thread hinges on the word how "effective" are subs that are smaller than 8". Well, probably before anyone can respond would need to understand what "effective" means. I have 6 13.8" drivers in large boxes and can only say that they are effective to a certain point.
Are small (below 8") subwoofers effective? If not, why do the exist? Is there an intended use? I am specifically curious about the 7"Epique subwoofer kit available from Parts Express.
From a science viewpoint, you want a speaker to be a perfect piston. The voice coil movement may not be a perfect piston in response to the signal. That can be improved with servo feedback. Real speakers have cone or diaphram resonances which produce distortion. So sub speaker makers have metal cones. Unwanted resonances are easier to control in a small cone.
But the smaller the sub cone results in less amplitude at the listening position its bass SPL.
The reason small subs exist is to sell small subs.
Get set up with Room EQ Wizard, build subs, measure, and report back!
Not sure what size and/or what kit to get. I am thinking at least 10". Although the SVS 3000 Micro is intriguing. I have no experience with any of the Part Express kits, and it seems like their plate amps may not be worth it. Maybe a Crown external amp might be the best choice. Any experiences with any of the kits from Madisound? I think their kits come with Speaker Power amps.
A wee problem with pricing though. Works if space is at utmost premium and money no object. I'd say get a bigger place and bite the bullet.
I can recommend the AIYIMA 800X. It’s a pretty decent 8-inch subwoofer for the money.
Just make sure to disable the noise gate, with it enabled, it can cut out at low listening levels.
Inbuild DSP is a plus, needs a mod, but well worth it.
Yes, in the previous comment I mentioned the Wiim app and OP replied that they had not tried it but had kind of tried the SVS one. I'd say it's worth another go on a big sub if you can use a real mic with the WiiM app.
any thoughts on the svs 3000 micro revolution? Or the Kali Audio WS-6.2?
Ok at low volumes in near field, if you have room get a bigger sub
You can still find these little Pinnacle Subsonic 6 (dual 6.5") and also the dual 8" version, for cheap. So similar idea to the little KEF and SVS but old design and not as good. I have both the 6.5" and the 8" and they work pretty well for extending the low end, paired with small bookshelf speakers. They are what they are, though, so not as good as using a larger sub.
Check these out. Used to have two SVS 3000 micro and they were fine, but Kali are very, very impressive at the price. Being taller than the SVS was a nonissue for me.
Interesting, but isn't this bigger than the SVS and a similar price*? I didn't really compare performance but it seems the SVS looks better, especially if small overall size is important. Kali is 14.5"x12.2"x11". SVS 3000 is 10.9"x11.8"x10.8". And the SVS SB 1000 Pro is 13.5"x13"x14.76".
*edit: I say similar price because SVS 3000 Micro price has dropped to $729 on Amazon right now
DIY kit or OTS? Link?
DIY. A SB Acoustics SB23MFCL45-4 and a quite thick and long 3D printed port that I had to bend to get it to fit inside the ~25 liter box. I do love bass and high SPL and really happy with how the two of them performs in my 3.8x3.6m livingroom :)
Interesting! I love the Kallax idea for storage / shelving, speakers can just fit in that 13x13 limit. I'm thinking can fit bigger cones in a cyclops design
by using a 4th order bandpass enclosure, with a PR for the front face, with the active driver behind in a sealed rear chamber.
Up to 15" total external depth to play with...
Three separate designs, one for just super down low, another LPF'd for up to 80kHz - option to test between going mono, freely placed, vs Stereo bass on those two.
reference Wolf's "Overdrive 10" project aka Kilauea
Then #3 a MBM Coupler for 80 up to maybe 180-200kHz, those definitely co-located in LCR stacks.
Obviously different drivers for each may be required not just box / PR tuning, and ofc active DSPing
But to start, I'm looking at simulators for modeling, designed to handle PR systems.
@Wolf used Unibox in stages since it can't handle the design as a single system.
Apparently VituixCAD can?
Any feedback welcome...
There's no replacement for displacement.
(Or was that a muscle car thing?)
