Small monitor speakers: seeking advice and suggestions
BigP
Happy Easter to everybody!
I'm looking for a pair of small pair of monitor speakers, I know this kind of question comes up quite often, but here I am :)
First thing first: I will be using them primarly for mixing purposes for my own music productions (pop punk tunes and light rock, but also I like to produce EDM, I use synth plugins), so I'm not looking for flattering speakers. Until now, I used headphones (Audio Technica ATH-M50x) but I found myself bouncing back and forth from my desk to my car to have a balanced mix.
Other constraints:
- my "studio" is in my untreated bedroom (11'x13')
- small desk and limited space (speaker enclosure width can be maximum 150-160mm or around 6", not more)
- desk is near wall, so front bass reflex port is preferable (right?)
Given this requirements, I found this suitable options:
  • IK iLoud Micro Monitor (250€ for a new pair): I've read excelent reviews about theese and listened to a lot of comparatives (I know, I know..) but I'm also worried about port chuffing at lowest frequencies, bass is a little overwhelming compared to mid and high frequencies, and also audio compression/distortion (especially bass) when increasing the volume.
  • Eve Audio SC-203 (I found a pair used for 350€, or B-Stock from an online shop for 420€ 3yrs warranty): found very very little about theese, but what I could find was all positive. They don't go low as the iLouds, but port chuffing is eliminated since they don't have a bass reflex port, also have a sub out (in case in future I would want to add one, maybe I won't, but who knows..). Should be a little more detailed compared to iLoud MM.
  • Eve Audio SC-204: maybe also theese will fit, but I've not searched for price nor audio quality yet.
Are there other alternatives that will comply with my requirements?
I know that with whatever I'll go I won't be able to do a professional mix & master since this would be my main monitoring system (and not a reference), also given how limited I am I must accept compromises of some sort, but I want something that is more than adequate and accurate for an amateur home studio, something that gives me less problems, or at least the less noticeable ones I can live with :)
Waiting for your inputs and suggestions!
dfuller
With the size limitations you've mentioned I believe you're better off just getting a decent pair of headphones. The iLouds are fairly flat but very high distortion, and the Eves... Generally just meh. Plus, considering that you can't really do anything about your room, I would trust nothing from it.
As far as headphones go I'd be inclined to go for the Drop/Sennheiser HD6XX.
Kachda
NY
Other constraints:
I have the micro monitors. At typical listening volumes (70-75db) I do not hear any port noise. And no hiss either with gain set to 0 (center)
They are good enough for listening to music when I’m at my computer (don’t like headphones), especially if space is a concern. however, i would never mistake the sound with my kef r3s.
timblocktoom
Just to chime in here, I have the larger iLoud MTM's and I'm having a world of problems with them due to being too close to the walls (due to desk space limitations).
I've moved them away from the wall to a position I can't really use, but just to test -- and it made a world of difference.
I may have to sell them honestly
