Small-diameter unbalanced RCA-to-RCA cables and EMI susceptibility
Good practice is to always connect to case/GND/Earth at both ends.
But if an AC grid powered component only has two prongs, doesn't that mean it is designed to float, double-insulated with an internal power common instead?
> Isolation "GND lifting" resistors are tolerable when they are bridged with properly sized capacitors.
Way above my pay grade, have you got a link where I can learn more about when these would be needed?
Is mixing earthed vs floating components in a chain part of what requires such measures?
This only works for balanced signaling, feeding a balanced receiver input. Not for unbalanced, where you really need milliohms of impedance for the shared GND connection. Twisted Pair cannot afford that (shielded or not).
If there's no way around it, that is tragic.
My plan is structured wiring based on STP / AoCAT for patch panels / snakes + stage boxes that could be used for AES/EBU and BOTH balanced (differential, pseudo) AND SE unbalanced
using RJ45 and Euro blocks wherever possible rather than XLR & RCA terminations.
Only using SE unbalanced for short patch runs.
Am I correct that you believe this plan cannot work no matter how short the runs or clean the EMF / RFI context?
How about a strategy of "try and see" and if audible or measured problems then fall back to Coax for unbalanced I/O?
Can Coax even be used with Euro block? or are separate patch panels required?
Reality is more like "don't care until it doesn't work"
For the context of analogue audio you only need to keep the airborne waves out where it matters.
Or even use CAT5 cables for audio and digital audio or even video, no one really cares as long as it works.
For real coaxial connections we've had this for decades
Of course you can try it and see what happens. But the physical issue remains, the high'ish impedance of the return conductor of the unbalanced line over STP. Depending on which devices are connected to the cable and what power supply schemes they have, you could end up with anything from perfectly working to unbearable hum/buzz.
Reading through these posts I sometimes get confused at what some are saying. Are some saying they connect unbalanced equipment without the shield connected at both ends? How is that going to work? Or are they giving the return current (i.e. ground) a separate wire to connect on?
Yes, at least IIRC -- the circuit is completed via a second wire connected to the "ground" of the gear at both ends, with the shield connected together with that return wire only at the source end of the connection.
For a RCA unbalanced interconnect, a Shielded Twisted Pair (STP) with the shield only connected at one end (hopefully the send end) and the two inner conductors carrying the signal will often work. But it won't be as good as a coax when dealing with power line related hum ad buzz.
Heck, Anticables often work.
A shielded twisted pair cable is specifically for BALANCED cable interconnects, the ones containing 3 pin XLR connectors.
Back in the day when cat/stp cables were in DIY fashion, I discovered that the pair I made was dual purpose.
Apart from connecting gear, I could also tell the points where electrical runs pass inside the wall or floor when I was measuring :facepalm:
And yet still fairly commonly used for single-ended connections. There is nothing that prevents a user from connecting the cable in unbalanced/single-ended configuration, as is very common in professional and may consumer applications. I often buy balanced cables for single-ended systems since the cost adder is minimal and that way I have a more general-purpose cable. The wire does not care.
Using STP provides several options for neutral/return(-) and shield connections. Signal return (-) is usually connected at both ends, with the shield connected at both ends to signal or chassis ground, or sometimes at only one end (which significantly degrades shielding and introduces a resonant antenna with frequency depending upon length). In a balanced configuration, the shield may be lifted (ground lift is often a switch on a DI box) to prevent or reduce a ground loop at the cost of reduced shielding.
Or Euro block. Or DB-25.
AES/EBU
for that matter, there are converters for nearly every digital audio signal format - ADAT, USB, TOSlink / S/PDIF
Ethernet of course
My thinking is, structured STP / RJ45 wiring for distance, usable for nearly anything, then just the termination interconnect for the last few inches.
If I need 6' or 11' just fabricate myself no new skillz required
Single-ended, RCA connections always feel like a lottery to me.
The word "Circuit" means "Going Around", so we know that there must be a loop. Even as children we learned with a bulb and a battery that no loop meant no light.
So if we send an electrical audio signal over any distance, there needs to be a Going wire and a Coming Back wire.
We also want to minimise interference, so we put the going and coming back pair inside a conductive tube and bond that tube to the planet's ground potential.
Single-ended RCA working says "hey, let's save money by making the coming back wire the same as the external, grounded conductive tube, what can go wrong!". It's then a lottery about what does go wrong. If you are lucky, everything is fine, if you are not, you have a difficult and sometimes impossible to fix problem.
Imma grab a random RG59 that comes up first in search... Belden 9104 https://assets.belden.com/m/67db90008685d44f/original/9104_techdata.pdf
The shield wins.
Well if anything it proves the comments above that coaxial ground impedance is lower than a CAT5 cable. Tho not by much compared to the conductor. Maybe 3 to 5 times. Is that a lot or not, i dunno.
But one thing for sure is that if you get anything close to 1-digit impedance on your ground connection, you're going to have a bad time.
