No.Is it theoretically possible for an unshielded, very small diameter cable with a tightly twisted pair to actually have superior EMI rejection to typical conventional shielded cable for unbalanced line-level audio connections?
I was under the impression that ferrite beads were mostly for preventing radiation of EMI from the cable rather than preventing the cable from picking up EMI. Is that incorrect?One can always double up with an inexpensive ferrite bead choke that clamps onto the interconnect next to the device input. Many are available on the internet. AC power from old style light dimmers, florescent lights and appliance SMPS often culprits of RFI.
It's easier to understand ferrite clamps as a series inductanceI was under the impression that ferrite beads were mostly for preventing radiation of EMI from the cable rather than preventing the cable from picking up EMI. Is that incorrect?
Interesting. You're right about them being rarely seen nowadays -- I've seen them mainly on power brick cables and the occasional USB cable -- but never for an unbalanced audio "interconnect."Another location is near the connector
Very intermittently -- not hum or static, more like fast chirping. Not enough to be heard when music is playing -- but noticeable when there's no sound if I happen to walk past the affected (powered/active) speaker with the tweeter/midrange driver near ear level. The other speaker, fed by a much shorter cable, never has that symptom, which led me to suspect a cabling issue. Investigation is ongoing, as the cable seems to be a pretty unlikely culprit.The twister pair reduces coupling from the H field, where as the shield protects the conductor from the E Field - hence shielded twisted pairs provide very good rejection of E-M fields.
In the limit, it is the net area remaining after “twist signal cancellation” that leaves a residual area for pickup, so if the twist are very very small, it would suggest to me that the induction pick up would also be low…. That’s a round about way of agreeing that a very small twisted pair is less likely to pick up H-fields. Anyway its been years since I was involved in this type of analysis - In the 90’s I had a intern do many studies and experiments on cables and he showed it all came down to the last “turn” or twist. Well, this is just from memory, so I might have forgotten stuff. Just do a search or AI question and you should get some reasonably reliable answers.
If you are really worried about EMI rejection then balanced inputs with high CMRR and Star-quad shielded cable is the way to go. I worked for a while on outside broadcasts, and the microphone cables coming back to the mixer 100ft away, basically lay alongside the cable used for lighting- in those days lights were high current incandescent lamps dimmed by thyristor, AC chopping waveforms (lots or EMI in the Audio band). How much noise was injected in to the microphone signal - nothing!
For audio interconnect over a couple of feet you are worrying too much - as other have said just get BNC- BNC and RG58 coax if you are really concerned - do you ACTUALLY have an EMI problem?
Sounds like SPDIF unlocked to meVery intermittently -- not hum or static, more like fast chirping. Not enough to be heard when music is playing -- but noticeable when there's no sound if I happen to walk past the affected (powered/active) speaker with the tweeter/midrange driver near ear level. The other speaker, fed by a much shorter cable, never has that symptom, which led me to suspect a cabling issue. Investigation is ongoing, as the cable seems to be a pretty unlikely culprit.
They do not have to be coax. You can use twisted pair with the remote end terminating at the amp input and its 0v reference. Then you can connect the shield at ground… not necessarily at the 0v reference and tie the 0v reference to ground though an inductor. I did this on my very first active speaker system where the amps and crossover were mounted on the loudspeaker rear panel. I lived about 10miles from a 200kW medium wave transmitter and RFI would get in to everything and the envelope (audio) would get demodulated, the above solution worked very effectively.Unbalanced interconnects must be coaxial with lowest possible shield impedance.
Coaxial design shields electric fields and cancels magnetic fields.
But, more importantly, really low shield impedance is the only way to keep nasty hum and buzz in check, which is created when there are balancing currents between gear (and there are almost always such balancing currents). The lower the impedance, the less voltage a current can generate along that impedance (Ohm's Law : U = R*I) --> less hum/buzz.
Yes. Not only for very small diameter cable. Reason: EMI impacts both wires equally, as common mode interference. The audio signal itself is differential mode, so much less susceptible to common mode interference.Is it theoretically possible for an unshielded, very small diameter cable with a tightly twisted pair to actually have superior EMI rejection to typical conventional shielded cable for unbalanced line-level audio connections?
no ....ALWAYSalmost always
What signal is differential in an unbalanced connection?Yes. Not only for very small diameter cable. Reason: EMI impacts both wires equally, as common mode interference. The audio signal itself is differential mode, so much less susceptible to common mode interference.
The cable shield is an antenna, which can both radiate and collect RF. Whenever the "GND" connections at/in the device are not up to RF immunity requirements, you may get a problem. Ferrites on cables help isolate the cable from the device, for RF. The more, the better. There are even cables with ferrite-loaded jackets for that purpose, used in harsh environments.I was under the impression that ferrite beads were mostly for preventing radiation of EMI from the cable rather than preventing the cable from picking up EMI. Is that incorrect?
The receiver looks at the difference between hot and GND pins. If both signals have the same voltage superimposed, it cancels, theoretically. But RF is tricky and will find ways to sneak into the device and will be demodulated.What signal is differential in an unbalanced connection?
Yes. If the shielding is connected at only one end, the RF suppression is poor, very poor. Should be connected at both ends against RF, or double-shielded cable to be used.The receiver looks at the difference between hot and GND pins. If both signals have the same voltage superimposed, it cancels, theoretically. But RF is tricky and will find ways to sneak into the device and will be demodulated.
This only works for balanced signaling, feeding a balanced receiver input. Not for unbalanced, where you really need milliohms of impedance for the shared GND connection. Twisted Pair cannot afford that (shielded or not).With STP all signal is carried by the twisted pair.
The overall cable shield is shield only, no signal, just as true for SE Unbalanced as differential balanced.
That shield can be chassis grounded at one or both ends, which then should usually be going to proper safety Earth.
There can be a shielding between every pair in CAT 4-pair but never heard of a case where that is necessary.
If you are concerned about EMF / RFI even if not currently perceiving actual problems convert to differential balanced.
And that should be default - if not digital - for long runs.
Good practice is to always connect to case/GND/Earth at both ends. Isolation "GND lifting" resistors are tolerable when they are bridged with properly sized capacitors.That shield can be chassis grounded at one or both ends, which then should usually be going to proper safety Earth.
