Small-diameter unbalanced RCA-to-RCA cables and EMI susceptibility
Bruce Morgen
All other factors being equal and assuming a typical line-level application, would a 2-3 meter length of very thin shielded RCA-to-RCA cable -- the type often used for old-fashioned composite video connections -- actually be less susceptible to the occasional audible EMI incident than a counterpart of the usual much larger diameter?
You can't compare a yellow composite video cable and a RG59 cable and say "all other factors being equal"
If we want to look at the eventual shielding performance in general, the answer is no.
Most of the heft of cables today is because of armor, not shielding. The larger RCA terminal ends are usually because they have some type of locking outer ring and/or an expanding inner pin.
You can have both shielding and locking terminals that will work fine on most newer equipment and not be so heavy that they strain the receiver/female RCA.
There are more cables today than ever before, and they can be job-specific, not too heavy or expensive, and actually be practical. I'm sure Amazon, PE, or some eBay vendor can fix you up for just a few quid.
Regards
I'm looking for what the applicable theory has to say by posing (what I thought was) an obviously hypothetical use case.
"red and white" analog RCA audio coax cables are usually anywhere between 30 and 150Ω, but can also be twisted pair.
"Yellow" video coax cables are spec'd 75Ω, RG-59 or RG-6. but for analog audio, impedance is not an issue.
In fact these latter are better as low capacitance makes a difference for analog audio over longer runs.
Shielding against EMF is a completely separate issue from all the above.
Some RCA cable are coaxial and some are a twister pair. If a twisted pair, then yes in principle the smaller and tighter the twist, the more EMI/RFI rejection. If Coaxial then diameter wont matter, but the shielding coverage is what matters.
AoCAT aka Quad Twisted Pair (QTP)
see AES-72 standardizes the transmission of multiple channels of analog audio (or digital, AES3) over standard CAT5e/CAT6 and RJ45/RJ48 STP infrastructure
A single shielded CAT cable can cleanly transport up to 4 pairs (8 channels total) because the 110-ohm impedance and high bandwidth of tightly twisted CAT pairs match digital audio requirements exceptionally well.
The shielding can be shared as PIN1 for balanced snake connections, but needs to be connected through any terminations to chassis, patch panels stage boxen etc
These can also be combined with DB-25 gear, aka AES-59
These can also be combined with DB-25 gear, aka AES-72
The OP was asking about unbalanced audio.
Which can be done using the exact same scheme.
In theory, there could be crosstalk between the four pairs inside the STP sheathing, you COULD use CAT7/8 I suppose, where each TP gets its own sheilding, but I've never heard of anyone actually doing this.
The wire itself is sufficiently shielded, you can’t improve much here. Whether the cable will have a characteristic impedance of 50 Ohm, 75 Ohm, or anything else doesn’t matter at all for analogue audio signals. But do focus on the RCA connectors. Don’t use the plastic ones but choose full metal ones instead, to complete the end-to-end shielding strategy.
On a sidenote: be aware that unbalanced cables are far from ideal, due to the fact that the analog audio return signal (equal to the inner signal current but in opposite direction) flows over the shield, the same shield that acts as an antenna for unwanted EMI signals. Shielding should be for shielding and safety earth, not for (return) signal flow. This is the subject of common mode and differential mode signals.
No, quite the contrary, see below. Low shield impedance is king, and a larger cable diameter tends to have lower shield impedance for simple geometric reasons, larger conductive cross section area.
For best EMI RF immunity use a cable with a braided shield plus a foil shield. The typical audio cables have a simple spiral shield which does neither have good coverage nor low shield impedance.
But typically, with 2-3m length, the unbalanced connection itself will be the limiting factor for low noise/hum/buzz. Low shield impedance is paramount, that is, reduce length if any possible and use a cable with the lowest shield impedance, like cables with double shields (triaxial cable):
Those are rather tiff and unwieldy, and not easy to terminate on a standard RCA plug.
If i remeber correctly Mr Carlsons Lab have a video about cheapo rca and analog video cables connected to his tester or amp. The tldw was cheapo rca buzzed and the viseo cable didnt.
Nope. Large diameter coax is of no use in mentioned 3m RCA analogue signal cable. Reason: the input impedance (to the amplifier?) will roughly be 10K Ohm or something. Even if the series resistance of the shield from a small diameter cable would be 1 or 2 ohm then that's of no influence to the signal transfer. Moreover there is no low shield impedance required for RF EMI. That's why we're using ferrite cores around the coax cable, to INCREASE the EMI impedance. You need low shield impedance in case you want to distribute or transmit RF power, but that's contradictory w.r.t. what's required here. Reducing the length of the cable is always good. As mentioned, the shield acts as antenna for RF signals. The longer the cable, the lower the RF pickup frequency and the larger its bandwidth for RF signals. Long story short: for interconnects use generic coax, all metal RCA plugs, add one or more ferrite cores in case you want to tackle EMI. By the way, ferrite cores increase the impedance for common mode RF signals but are fully transparent to differential mode audio signals.
Off topic: what I use for my unbalanced interconnects? => BNC (instrument) cable combined with metal BNC to RCA plugs. BNC (instrument) cable is fully transparent from DC to several hundred MHz, sufficiently shielded, manufactured in large quantity so rather cheap and not affected by the high end audio markup industry. I can say with confidence that, independent of price, for unbalanced interconnects there is nothing better than this.
Take a piece of hollow metal cube. If you want to double the scale, the volume will increase 8 times. The mass will increase 8 times if you want to keep the same scaling including wall thickness. The mass will increase 4 times if you want to keep the same wall thickness. The wall thickness will reduce by 4 times if you want to keep the same mass.
So no, "all factors being equal" is too difficult to do when you don't consider the other factors.
And if you want to consider all factors, then that's called "real life products".
I like to use this video as example. Want to change something without specifying how, and the video author has to think up 3 different cases.
When we talk about real world products, the ultra thin yellow RCA is a pretty horrid construction. The cheapest **** may not even be an actual coaxial cable as can be seen in this video
I've taken apart one myself (of perhaps slightly better quality), and at least it was coaxial, but the other conductor is just copper wire strands wrapped around.
A *proper* audio cable, good enough to see use in studio environments, will have at least one proper braid or foil layer, if not more, and the ground may or may not be on an additional conductor, to keep the conversation simple. Take CANARE L-2B2AT for example, that's a common cable for audio.
I'd vote "no" for all practical purposes, and often the opposite is true because shielding is of physical necessity thinner. The only argument in the case of "all other factors equal" is for reduced cross-sectional area for EMI field coupling but that's a pretty weak argument. The catch to me is that all factors are virtually never equal comparing coax of different diameters. Larger coax can be had with additional and heavier shielding than a thin coax, heavier gauge wire (center conductor and shield) for lower loss, thicker outer jacket (as well as dielectric), and be made more rugged to withstand handling and connect/disconnect cycles, so in general I would choose the larger coax.
Not always true, not always coax
see my post above on CAT STP as analog wiring.
Is it theoretically possible for an unshielded, very small diameter cable with a tightly twisted pair to actually have superior EMI rejection to typical conventional shielded cable for unbalanced line-level audio connections?
