Small 2-way speakers with linear on-axis and power response characteristics (Scan Speak and SB Acoustics drivers). H&V off-axis measurements included
10 % more ore less in volume won't change much. Maybe 1 or 2 dB?
HI.
I am trying to make a pair of these. Just cant find a good place for that extra 0.1 mH inductor.
Is this fine? (picture below)
Is that too close to the one with metal core?
You can do whatever is possible, but keep the coils as far apart from each other as possible and 90 degrees rotated (see You did this). Caps and resistors position to these are irrelevant.
Hi All,
I am currently tackling this build using MDF, created an account to say a huge thank you to xMechanik for creating a DIY guide. Was wanting to tackle a speaker build that had it all from start to finish (as this is my first speaker build and i think the biggest challenge was learning the crossover) so thank you for this.
I will provide photos once it is done.
Keen to know what amplifiers people are using with these speakers?
Hi All,
I am almost done building these as well and was planning on using the Douk Audio A5 to drive them as it has a high pass filter and pre outputs that can run to a subwoofer which based on the review/measurements of this speaker will help it immensely as it's best paired with a subwoofer.
I was also planning on making a pair and giving them to a friend and was just going to use a standard AV receiver for the bass management / crossover and I suspect it would have enough power to drive these?
Curious what other people are doing and think about my plans as well.
Hey! I have finished making these, and they sound truly fantastic! Like, truly incredible!
I am about to assemble another pair for my friend, so I am going to post what I ended up doing, and then people can comment if they see any small changes that I should make for my friend's pair (and now my sister is also asking we make a pair).
Ok, I made the cabinets with a friend who has a fantastic woodworking station in his basement, so I got way better results than if I were to hack at it alone.
For the speaker assembly, I put silicone around the port junction to the speaker as I did not want air to sneak out and around it, and also help with any port resonances.
Then I did what @Woody99 recommended for his speaker build and lined the walls with some acoustic panel material I got from a friend. I think it is a polyweave acoustic panel? It is rather homogeneous and tightly woven fibers so I don't know if people think that would be adequate or not.
I also did window bracing right in between the tweeter and woofer. Not sure if people typically sand and round the edges or if diffraction is of any concern or totally fine the rough way I left it.
Then more of the wall lining.
I had some leftover door sealing material that is foam stripping that I think worked great as a speaker gasket, as it was very absorbent and compressible (I accounted for this when routing down the lip, so the drivers remain flush with the front).
Then I put the crossover resting on the bottom and then, just for kicks put a little bit of polyfill in the speaker as well.
I just used zip ties to attach everything and did not use hot glue, as I wanted to make sure I was happy with all the positions, and when it was done nothing seemed to be able to rattle, so I did not think glue was needed.
I was too excited to paint them, so I just loaded in the drivers as I needed to know how they sound.
I was totally blown away by how great they sounded!
Just for completeness sake, I uploaded the few/minor EQ filters as recommended by the Klippel measurements into my WiiM streamer and no complaints there.
I also put them on some leftover acoustic panel that I had so I can slide them to the front of the desk when I am just listening on the couch in the sun room and then slide them back when at the desk.
I have been listening to these non-stop for about a week and now am posting about it on here!
I guess I should paint them, but they get so much use that I will have to find a day when I won't be using them.
Anyways, happy to see if people have any recommendations for even small tweaks.
Mostly:
1) Any changes you would make to mounting the port?
2) Any changes to the window bracing? (I accounted for this volume and added it to the speaker depth)
3) Any changes to the wall lining? (We have Sonopan up here in Canada so I can always use that, but that sheds more particulate matter, and so I felt that the polyweave material was probably the best. I could also use foam or mass loaded vinyl or nothing).
4) Any changes to fill material and amount? I heard that you don't want to overfill a speaker and so with the wall lining, I thought to keep it on the more minimal side. We just did a home renovation, so I have leftover rigid foam, polyfill, fiberglass insulation, and rockwool so really I could put whatever and however much of anything (or even a combo of any and all)
5) Any changes to the gaskets? Or as long as the speaker ends up flush, then all good.
Thanks @XMechanik for the incredible speakers!
If you ever make speakers with even more output for a home theater, I'll be the first one to make them.
Ok now back to listening!
My only nitpick is using black screws over silver. Really elevates the look, silver/chrome just always look very out of place to me.
Polyfill doesn't really have much of an effect in speaker boxes, and mineral wools are generally ill advised in a ported speaker as there's a risk of fibers being thrown about into the room. I don't care for foams as they eventually break down into crumbles. My favorite material is cotton based insulation. Not sure where you would source it in Canada but there's probably a few options. It's so much better than anything else I've used I don't really bother with other materials anymore. My go to are Sonic Barrier acousta blue, henry ultra touch, or ATS acoustics cotton insulation boards.
Thanks!
Yeah I was just too curious to see how they sound so I used what I had. But when I paint them I am going to get black screws for sure.
Sounds good. I'll see what I have.
Hy. I am looking for speakers for my hometheater. I don't bother about THX level output but I am afraid that these small speakers could be just too little even with a subwoofer in an approximately 40m2 (430 sqft) basement room.
Can anyone recommend me something matching?
Regards
Clemens
Hello everyone,
After reading the many great posts and opinions on this forum regarding the Mechano23, I decided some time ago to build a pair of these speakers myself. I was fortunate enough to hear them beforehand at the home of an audio-enthusiast friend - they were simply magnificent!
I also wanted to build the version with the passive radiator, as that was the one I had heard. I gathered all the information and the various small modifications discussed on the forum, and then began placing my orders. When you lay everything out, it’s actually not that much equipment required!
And here is my brief construction report on that.
First, I assembled the crossover, taking care to account for the magnetic interactions between the coils. For the wiring, I used a braid of silver and copper cables.
Next, I worked on the wood. Since I don’t own the tools to precisely rout out the circular openings, I cut the openings for the drivers using a jigsaw. This shouldn’t have any impact on the final sound, though.
I’ve tackled a DIY project like this before: I built a replica of a conical horn belonging to a friend, and I ran into major difficulties when gluing the rather heavy boards together—they kept shifting whenever I tried to clamp them in place. This time, I wanted to make the process easier and achieve better results.
That’s why I looked into using biscuit joiners (Lamellos). That was the solution - nothing could slip out of place anymore!
Finally, the interior was insulated. I lined the inner walls with an insulating felt. I did not use any additional filler material, as I wanted to test the sonic effects first. More insulation can easily be added later through the opening for the passive radiator.
After painting and installing the drivers, the moment had finally arrived. My "Mechano" speakers were at last complete following a long construction phase, and I think they turned out beautifully.
But how do they sound?
From the first music tracks, I could tell that something special had been created here. To my ears, the sound is very well-balanced - remarkably so for such a small speaker. The bass reaches sufficiently deep, and the midrange offers excellent resolution. Given their size and the price point of approximately €480 per pair, the Mechanos are a fantastic choice - for me, and surely for many others as well. (Electronics used: Topping LA90/D50III/A50III/P50.)
I also experimented a bit with vibration absorbers, which I found really brought the midrange to the fore. The bass also became tighter. Of course, this is just my personal impression.
But now I wanted to hear them in comparison to my existing horn speakers. The comparison isn't fair, I know that. Horns always give me a lot of fun and that's how it was here. The horns, of course, were ahead. Fundamentals and resolution, bass and dynamics always inspire me.
Nevertheless, I love the Mechano's because of their fine and clean reproduction and I'm glad I built them!
Many thanks to Xmechanik and Amir and to everyone who commented and contributed a lot here!
Many Regards
Franz
Hello Franz,
My two cents: No rebate for the drivers, especially the tweeter, produce diffractions and thus uneven frequency response.
It’s a shame to degrade such a high-quality speaker.:confused:
I got a port tube that is 35.5mm diameter at the inner side and 38mm at the outer side, and is 146mm long.
How much will it differ (in speaker performance) from the 35mm/145mm monacor recommended tube?
