Small 2-way speakers with linear on-axis and power response characteristics (Scan Speak and SB Acoustics drivers). H&V off-axis measurements included
Machano23 sealed? If I know I’m going to use these speakers with a subwoofer, any reason not to build it sealed? I have limited space in my office and building sealed reduces box size (with the usual higher bass f3). I know the response has been modeled by another member but are there any other sound quality issues to building it sealed, ie changes in group delay, phase etc? If the change is gonna degrade sound quality I’ll build it ported or with PR, but if not, I’d prefer building it sealed. Thoughts?
I´ve been thinking the same thing. My old rear speakers are Wharfedale Diamond 9.0sr (at least 20 years old) and they sound a "little bit" different than Mechano 23:s in the front. The issue is space. My room is quite small and I can´t place full size speakers in the ceiling, so I was thinking of building closed and downward tilting Mechano´s to handle surround. Bass will be weaker off course, but I think the ceiling placement will lift it up to match the front speakers close enough. The other idea is to use completey different speaker, for example https://sbacoustics.com/product/5-sb13pfcr25-4-coax/ or even it´s smaller sibling https://sbacoustics.com/product/4in-sb12pfc25-4-coax-paper/. What you guys think?
Got the woofers ordered for these, already had the tweeters. I was looking for a lower cost bookshelf with good linearity and dispersion that used cabinet material a bit thicker than what is usually found at these price points. I also wanted something that had been proven on klippel. I enjoy building speakers, but I absolutely despise the filter design process. This speaker ticked all the boxes. Hopefully I will return shortly with finished speakers.
I'm considering using passive radiators over the port, as I intend to use the speakers for light mix work and production. I find upper port resonances can be really annoying in these cases, especially with piano. Looks like the SB racetrack PR would work well.
You mean instead of the port, right?
Note that the displacement volume of the passive diaphragm should be significantly larger than that of the active driver, two or better three times as large, if you want to fully utilise Xmax of the active driver.
yes
I'm aware, everything is simmed in vcad before pursuing.
Oh no, Madisound sent me the wrong woofers, I ordered the SB13 and they sent me some new model SB15 woofers. Dangit was hoping to have the speakers running this week.
Very close to being finished, just need order the PCB's and xover components and wait for the correct woofers to arrive from madisound. This was my first time using baltic birch, and the sheets I had were 9mm, so I had to cut everything twice and glue the panels together. Didn't quite come out perfect but good enough. There are some saw marks on a few pieces but I can live with that.
My intent was to make a baffle out of thin strips glued up to show an array of plywood lines but unfortunately I couldn't get the face of that to come out clean, so I just slapped an additional layer of 9mm ply on top.
Terminals and PR installed. Finish is just some rubbed danish oil. I may do an additional layer of shellac.
Looks pretty impressive. Have you considered chamfering the woofer hole? Are you going to take some measurements when you're done?
My construction method typically makes it a little tough to chamfer driver holes as I usually cut the baffle wide to flush trim, and then cut my router holes to ensure they're dead center. It's probably not the most ideal method but it works for me. I've been looking at ways to trim out the baffle mount walls a bit. There are a few options, one being an inverse round over bit which aren't particularly cheap. I'll see if the response warrants a chamfer and go from there. I'm open to other ideas on how to accomplish this.
I will take measurements once they're done to verify the build is performing to spec.
edit - I'm finding a good selection of undercut router bits, so I should be able to chamfer the woofer mount at some point.
Looks very harmonious, congrats!
I would leave it raw after oiling. How did you do the final sanding/polishing?
Would be very interested to know about your experience with the racetrack passive radiator, once the woofers are in place. You have never tried this one, have you?
Thank you. The process was anything but harmonious requiring a lot of clamps and time. The pieces really wanted to shift a lot.
Just sanded to 220 and applied the oil with a rag, lots of rubbing it in. Didn't do anything after that.
This is the first time I've used a passive radiator. I sold my kali lp6 due to the port resonance being annoying, and a recent bookshelf I made had the same problem so I figured I'd try something different. I don't find these resonances too bad when listening, but if one mixes or plays instruments through speakers with them it can become very obvious.
Just stumbled across your build @XMechanik, incredible! Was hoping someone could glance over my parts list in the images please? Need a sense check on what I’d be ordering as parts at soundimports have different V or W associated with them so I’m a bit unsure.
Sourcing xover components under this tariff BS has been a hassle. I ordered half the components and will try and pick up the rest later this week. Some of the components are differing values such as an .40mh inductor vs the original .39mh, but thanks to @XMechanik providing his Vcad file, I was able to see what changing some values will do. I couldn't order from Solen as a $15 order turned into $80 after tariffs. Doesn't help that some places are just not shipping to the US right now either.
This is what i ordered from Sound Imports: (some things changed due to availability hence the screenshot of exactly what i bought / couldn't get the Dayton DMPC 2.0 & 3.3 so Audyn instead)
p.s. i was advised not to buy the wirewound resistors, due to inductance, which is why i bought the MOX, or Metal Oxide film resistors.
Drivers Ex VAT Inc VAT
Scan-Speak Discovery H2606/920000 Dome Tweeter € 72,64 £ 61.77 | € 87.16 £ 74.12
SB Acoustics SB13PFCR25-4 Woofer € 47,02 £ 39.98 | € 56.24 £ 47.96
€ 119.66 £ 101.75 | € 143.40 £ 122.08
Inductors:
Jantzen Audio 000-1679 | 0,33 mH | 0,26 Ω | 3% | 18 AWG (1.02mm) € 12,31
Jantzen Audio 000-1839 | 0.39 mH | 0.42 Ω | 3% | 20 AWG (0.8mm) € 9,83
Jantzen Audio 000-1848 | 0.56 mH | 0.51 Ω | 3% | 20 AWG € 10,66
Jantzen Audio 000-2430 | 1.5 mH | 0.94 Ω | 3% | 24 AWG (0.5mm) € 7,36
€ 40.16
Capacitors:
Jantzen Audio 001-0228 | 0.82 µF | 5% | 400 V € 2,46
Dayton Audio DMPC-2.0 | 2.0 µF | 5% | 250 V | or Audyn Q2/2.00/250 € 3,29
Dayton Audio DMPC-3.3 | 3.3 µF | 5% | 250 V | or Audyn MKTA/3.3/160 € 3,29
Audyn MKTA/6.8/160 | 6.8 µF | 5% | 160 V (ok) € 7,85
Jantzen Audio 001-6144 | 18 µF | 5% | 100 V € 2,46
Jantzen Audio 001-6150 | 27 µF | 5% | 100 V (ok) € 3,29
€ 22:64
Resistors:
Jantzen Audio 002-0469 | 8,2 Ω | 5 W | 5% € 1,64
Jantzen Audio 002-0478 | 12 Ω | 5 W | 5% € 1,64
Jantzen Audio 002-0481 | 15 Ω | 5 W | 5% € 1,64
€ 4:92
Crossover
€ 67:22 £57:16 ex VAT
€ 81:26 £69:10 inc VAT
Extras:
Monacor MBR-35 adjustable bassreflex port
Dayton Audio BPA-38G HD Binding Post Pair Gold
Monacor MZF-4012 Recessed Head Wood Screw | Ø3,5 x 12 mm
081-420 Deep Thread Pan Head Screw | 4.2 mm x 12.7 mm
Monacor MZF-8614 Hexagon Socket Wood Screw | Ø4 x 16 mm
ICC 2.5mm Red/black speaker wire
I can imagine sourcing parts is a real PiTA stateside at the moment!
Finally got the speakers running. Sounds pretty good, I'd argue damn good. I am noticing a difference in mid range in my measurements but audibly it doesn't seem to present an issue. Both speakers measure identically so I believe the xover was done correctly. I will measure the impedance later today to rule out the xover. I am also currently running the speaker without any dampening material as I await for it arrive.
Word of warning, if you get Dayton caps for the 27uf and 18uf, they are huge. I had no idea they would be this large and it was tricky fitting everything on the board but I managed to get it all placed well.
My impedance looks wrong, so I guess something is mis-wired. I'm not entirely sure what though.
Show the underside of your xover. Did you sand or scrape the enamel off the ends of the inductor wires before soldering?
No but it's not needed on the inductors I bought, they already come with bare wire on the ends.
The underside is a bit of a mess. I'll share a pic if I can't figure it out.
Ok I figured out the problem pretty quickly, back to soldering.
