HighFutility
- Joined
- May 8, 2022
- Messages
- 224
- Likes
- 195
Can anyone recommend something to seal the bond between the drivers and the MDF?
I like this foam tape.Can anyone recommend something to seal the bond between the drivers and the MDF?
I just quickly tested mine out before veneering them. I had the exact same thoughts. The vocals sounded hollow like. Im going to check my PCB and make sure I input everything correctly.Nope i used CNC
Btw. i created pcb mount if you have 3d printer and some M3 5mm heat inserts (3mf in mechano23-xover-mount.zip). I recommend to use foam sound dampening touching the pcb to eliminate vibration transmitted to the pcb.
I already put them together without sound sound dampening (waiting for order) and the sounds good but vocals are somehow very directional (almost hollow like). Its little bit strange. Maybe it will help sound dampening or i made mistake somewhere.
There are a couple of other threads about 3D printed cabinets, including links to some tests people have done. IIRC at infill >50% you get similar performance to various woods. Another option is to print an inner and outer shell and fill the gap with a plaster/PVA mix. You can either print the shells separately with spacers, or use an infill you can pour through, like gyroid with the right density. A similar technique should work with sand or similar, but I haven't seen measurements for that.I've hit many, but not all of the pages here... Has anyone tried a 3D print of the cabinet? I've modeled one up, tweaking the dimensions slightly to a) fit on my printer in 2 parts and b) accommodate some more extensive bracing and a thicker front baffle
Yes, at first I was interested but I didn't have the time or the filament to spare. I can actually print full cabinet on my voron 2.4 350. In future i want do some experiments with infill like making actual internal volume just with inflill, so no walls, or optimize infill density is some places/patterns. But for this i need to learn simulations. But about your question, yes 3d printed cabinet could work just fine, maybe you can fill walls with plaster+pva glue mix.I've hit many, but not all of the pages here... Has anyone tried a 3D print of the cabinet? I've modeled one up, tweaking the dimensions slightly to a) fit on my printer in 2 parts and b) accommodate some more extensive bracing and a thicker front baffle.
I’m a new member building the Mechano23 with wineds’ PCB. I have a question about the nomenclature of the capacitors. Is C3 27uF (per wineds) or 18 uF (per XMechanik’s first post)? Similarly, what are the values for C2 and C4 on the PCB? The nomenclature for the rest of the components are consistent. Thanks.Thanks. I contacted the PCB vendor (JLCPCB) and they said a public account was not possible. If anyone knows otherwise I'm all ears. However its not that hard to order yourself. Just setup an account and upload the RAR file. With fastest shipping I had them in just over 4 days. I have uploaded the files and link to JLCPCB ordering instructions to github here :
Mechano23-xover/README.md at main · wineds/Mechano23-xover
Mechano23 xover. Contribute to wineds/Mechano23-xover development by creating an account on GitHub.github.com
I had the same question. It’s not xmechaniks first post. I did the same thing - lol. Luckily I caught it early.I’m a new member building the Mechano23 with wineds’ PCB. I have a question about the nomenclature of the capacitors. Is C3 27uF (per wineds) or 18 uF (per XMechanik’s first post)? Similarly, what are the values for C2 and C4 on the PCB? The nomenclature for the rest of the components are consistent. Thanks.
I added a note to the first post that component numbering in VituixCad and XMachina schematics may differ.
The XMachina schematic was included there as a curiosity, I was a bit surprised that optimizer managed to create an E24 component where needed with only the E12 list available. (C6 and C7).
Interesting point. Below is my attempt to explain this effect, not necessarily completely correct or complete so please share your interpretations or remarks.I have a question: In this Mechano23 thread I don't understand why Vituix graphs show a crossover frequency of 3.5kHz while Amir's measured graph show à 2.5kHz Fx.
Did I misinterpret this last one? Does the near-field measurement not be able to render the actual Fx?
if Amir would have presented the complete woofer response raised by 6dB compared to that of the tweeter
