This is a good demonstration. Maybe not so good as far as what is used and where it is placed.
Good idea, there are loads of 'how to build your own' guides regarding diffusers on the Internet.DIY is something I like, so I can build, or have something built.
I will have my Daughter come down and do some clapping for me later this evening.
That's pretty creative! Those molded diffusers are cheap anyway though.
Make, or buy, an original to how you want the diffuser to be... then you just need free newspapers/general mailbox junk/..., wallpaper glue, water and plenty of time. Some saran wrap could help it get loose from the original as well. And some appropriate paintjob.
This looks pretty sweet. Thanks Mr. Nightlord. Also something my Daughter would have a blast doing, even better. Basically papier mache. Thanks.
Our fearless leader can be a bit detached from what us normal folk consider cheap.Not here. They cost $100 each.
You called it. My reference is wood RPG style diffusers which are quite a bit more money.Our fearless leader can be a bit detached from what us normal folk consider cheap.
No new recipe, it just reminded me of doing papier-mache. I may experiment with this.Exactly papier-maché in my book. Perhaps you have another recipe though?
