fpitas
Maybe you pay extra for that?a bad solder connection
Perhaps the ground connection is what's separating? But then I'd expect some hum.Hmmm...in the case of a bad solder connection...or really a bad connection of any sort, wouldn't the impact be either you have a signal or you don't? I doubt you'd have a signal but it would be less trebly or "airy." I've had situations wear a connection was iffy and the effect was if the cable was moved the sound would cut in and out in very obvious ways. I mean there's been a fair number of fun tests done over the years where the signal was run through coat hangers and potatoes with no notable audible impact at all so I'd think as long as the connection in the wires isn't completely broken you're not likely hearing anything audible that's more subtle than the sound cutting in and out with maybe some related staticky noises.
Hmmm...in the case of a bad solder connection...or really a bad connection of any sort, wouldn't the impact be either you have a signal or you don't? I doubt you'd have a signal but it would be less trebly or "airy." I've had situations where a connection was iffy and the effect was if the cable was moved the sound would cut in and out in very obvious ways. I mean there's been a fair number of fun tests done over the years where the signal was run through coat hangers and potatoes with no notable audible impact at all so I'd think as long as the connection in the wires isn't completely broken you're not likely hearing anything audible that's more subtle than the sound cutting in and out with maybe some related staticky noises.
Not always on a stereo pair where the grounds are tied together on both sending and receiving sides.Perhaps the ground connection is what's separating? But then I'd expect some hum.
it is in fact an artisanal solder connection.Maybe you pay extra for that?
If the amplifier driving the cable is marginally stable, the variations in R, L and C of the cable (likely mostly C) could cause an amplifier on the verge of losing it to sound oddly different or outright start screaming at above audibility frequencies. On competent equipment, the cable variations among reasonably competent cables would have no sonic effect.Sorry to say but it's your imagination. The cables do not have a sound unless they have been drastically modified and even then why would you want colored cables?
