Watch the 6dB or so HF peak on the 530EN, which I gather is similar to the 120E ancestor model I have here. It *can* breathe life into dull 60's orchestral recordings though and even into modern hot cuts of rock music, I don't find it an issue, BUT! the phono stage MUST be able to take the peak without overloading or ringing. The 540 doesn't have this peak and the 740 tested with same stylus, has a traditional recess in the response. You'll need to translate the pages for the text, but the response plots will tell you what you need to know
Innerhalb unser Familienübersicht ist das Audio-Technica VM740ML das größte und mit knapp 330 Euro t
www.lowbeats.de
Mit dem Audio-Technica VM540ML betritt das zweifelsfrei interessanteste Tonabnehmersystem der VM-Se
www.lowbeats.de
Das Audio-Technica VM530EN ist das 200-Euro-Modell der VM-Serie (siehe auch Familienübersicht VM-Ser
www.lowbeats.de
P.S. You don't need a turntable confection like the FFYX T224 you know. A Rega 8 or 10 will do better (in the bass) (I bet a modern Technics would as well - SL100C anyone?) if carefully sited and the engineering is in all the right places, if not a posh finish! I'm a Notts Analogue fan but I don't think they make or export many! - A Spacedeck with Rega RB300 absolutely demiloshed a 'well set up' Scottish model we UK flat earthers worshipped at one time and the deck and arm cost less than the deck only of it's 'pedestalled' competitor...
As for what I need . . . Well, if I were just going to listen to music, I'd have someone smart set up a decent modern system for me, with a good DAC, a good modern amplifier, and good speakers.
If I want just to listen to vinyl, I don't need anything better than my Sansui SR-525 with the old SV-27 cartridge on it with a conical stylus. When I listen to it, it sounds superb to me.
And today I received a Realistic Elac Miracord 45 in superb condition. It's a beautiful table, and it sounds great.
So I seriously don't need anything better than that.
But, as King Lear said,
O, reason not the need: our basest beggars
Are in the poorest thing superfluous:
Allow not nature more than nature needs,
Man's life's as cheap as beast's . . . .
Lear was an old man who wanted his hundred knights. I'm no Lear--but I'm an old man, and when I was young, I wanted a good turntable, etc. I couldn't afford a good system. So now I'm buying either nostalgic stuff or funky stuff that looks cool to that younger version of me, who was taken with the appearance of things that he couldn't afford.
That's precisely why I'm buying the T224. I think it looks cool. And I'm sure that it will sound entirely fine to me.
