- Joined
- Feb 2, 2019
- Messages
- 400
- Likes
- 493
As @Roland68 said, look for one with a bore of ~6mm. Either D-shaft or with the little screw to fasten in (which you could use a larger bore). It's basically the same size as the Schiit Jotunheim.Well, Is there any way to make this amp more beautiful by replacing its volume knob with a big red one? Where can I buy volume knobs shat fit this box? It will look soo elegant with one and more suitable for a feminine lady.![]()
The ones I purchased are from the links below:
11.31US $ 13% OFF|High-gloss Golden Stainless Steel Knob Solid Stainless Steel Knob Potentiometer Knob 30mm Diameter - Shell&body Parts - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
5.99US $ 18% OFF|1PCS 38mm/Aluminum Alloy Solid Volume Knob Audio Power Discharge Potentiometer Knob Gold Silver/38*20*6mm|Amplifier| - AliExpress
EDIT: Maybe one of these? Diameter is a little small though, look for 30mm-35mm.
1.19US $ |Solid Aluminum Alloy 25 X 15.5mm Volume Rotary Control 6mm Dia Potentiometer Cap Knob - Switch Caps - AliExpress
1.88US $ |High-end Aluminum Knob Potentiometer Knob 25*15.5*6mm Volume Switch Rotary Encoder Knobs Silver/black/red /blue/gold - Switch Caps - AliExpress
