- Joined
- Feb 2, 2019
- Messages
- 400
- Likes
- 492
Maybe someone can send in a modded version for Amir to test (with and without the DC bypass mod).
do you think what I perceive as improvements will be detected on his graphs?Maybe someone can send in a modded version for Amir to test (with and without the DC bypass mod).
Maybe? One way to find out.do you think what I perceive as improvements will be detected on his graphs?
perhaps my perceived improvement may be greatly due to the placebo effect.Sigh, just what we needed, perpetuating magic tricks![]()
Well, you didn't try the Sabaj amp did you? For me I'm glad I got my money back, there was 0 sound difference and the Sabaj amp has magnitudes more headroom than the Sinxer, if I ever need it.I am deeply sorry that you returned this amp without knowing what it sounds like after the mod. Why did you return this and I dont understand why you got a Sabaji instead. I agree it is cheaper but.....
Actually there is no difference between balanced and unbalanced inputs on the SA-1. The unbalanced input is balanced before the potentiometer and amplified to the same level as the balanced input.Well, you didn't try the Sabaj amp did you? For me I'm glad I got my money back, there was 0 sound difference and the Sabaj amp has magnitudes more headroom than the Sinxer, if I ever need it.
But yes the SA-1 seems nice with a balanced DAC + from its XLR output, but that's not super versatile though is itI prefer amps that work just as good on all inputs and all outputs.
Sorry, but the preamp section of the SA-1 is of course active.I've just acquired an SA-1 and using it as a preamp for my stereo amplifier. Chain is Topping E50 -> SA-1 -> Amp. I am getting a pop from the speakers when going from off to pre switch. Is the Pre setting going through some active part of the amp causing this? I noticed the SA-1 gets warm in just Pre mode as well. I was hoping the Pre function would be passive.
This is an active amplifier so there are no passive functions, it always goes through the amp.I was hoping the Pre function would be passive.
Found the issue, cheap XLR cables.That maybe but that noise at 4-6 oclock is noticeable , try it yourself with no music playing it's a dead giveaway but most with hearing damage here can't hear it.
One of the reasons I make my own cables...Found the issue, cheap XLR cables.
thanks. I am really looking to tame the Ananda in the highs and make them more bass and warmth more musical. I listen to Rap, Hip-Hop reggae, and r&b. And Spanish music. I like vocals to shine too in females or in males. Just want to make sure I pick right amp. As I'm not sure if I over did it in the Dac department with the D1SE.Both will be absolutely fine. You are buying a amplifier after all and not a equilizer
If you are looking for a balanced headphone amp then I think the SA-1 is a good choice. For me it reproduces music on my AKG K812 just as well as my Violectric V100. And the K812 is known to be a bit bitchy (in reality just honest) in the treble range and it also reproduces the bass rather neutrally.thanks. I am really looking to tame the Ananda in the highs and make them more bass and warmth more musical. I listen to Rap, Hip-Hop reggae, and r&b. And Spanish music. I like vocals to shine too in females or in males. Just want to make sure I pick right amp. As I'm not sure if I over did it in the Dac department with the D1SE.
Audeze only wants you to wear them when you touch your LCD-5.I bought the Audeze LCD-5 as it matched my Singxter perfectly. It is now going to be burned in as some dudes recomennded. Audeze provided gloves but I am really expected to wear them every time I listen to the phones? I run them with the gain set to low.
You won't find much in this size, maybe silver or gold.I know this is a technical forum but I love cute things and what I suggest will improve the wife acceptance factor of your gear as I am a stylish fashion lady myself.
Well, Is there any way to make this amp more beautiful by replacing its volume knob with a big red one? Where can I buy volume knobs shat fit this box? It will look soo elegant with one and more suitable for a feminine lady.![]()
