So it won't be dual mono? I thought you would just put two SA-90s in a common housing and only appropriately adapt the already very high-class preamplifier (SA-1 v2) by supplementing it with additional inputs and ofcourse a sub out.
Best regards
And it is precisely for these requirements that an integrated amplifier makes little sense.
The manufacturer has little potential to save costs with a real dual mono setup, and large and heavy packages are exponentially more expensive to ship, which also has a significant impact on the final price.
There are several manufacturers who have tried exactly this balancing act, but either the integrated amplifier was significantly more expensive, or the entire device was significantly castrated, often even both.
Customers should finally understand that the usual 2.1 SUB outs are unusable in 95-98% of amplifiers.
It would be much better if
@tom.chen installed preamplifier outputs (preferably 2 x) and power amplifier inputs. For normal operation, the pre outputs would have to be connected to the power amplifier inputs via bridges or short cables.
But now the customer would have the opportunity to decide for themselves how high-quality their 2.1 or 2.2 configuration would be and the volume control would be retained for the entire system.
He could now connect any analogue or digital solution for 2.1 or 2.2 in between, MiniDSP, the t.racks DSP 4x4 Mini (Pro), FIR Convolver, various DSPs (e.g. Wondom DSP modules under 50 $/€), 2.1 crossovers, subwoofer crossovers (also from the car sector from 20 $/€)
That would be an intelligent and useful solution for everyone that only generates minimal costs.
