Sorry, I thought everyone disliked CLASS AB amplifiers, so I haven't been on the forum recently. No offense. There may be a stereo version in the future, which is already planned. However, this will be an integrated amplifier with volume control.@tom.chen
It's very rude not to answer when someone asks. Did I offend you?
Thank you very much for your interest in SA-90. Actually, this amplifier is mainly designed for desktop HIFI users. They are small and can be used on the desktop. In addition, it has very low noise floor and can be used as an amplifier for planar headphones, but you need another adapter cable.Wow, those are some impressive power figures! Any word on pricing and a release date? Also, what's the design philosophy behind it? Class D? I'm really curious to see what Singxer comes up with. Keep us posted!
the SA-90 's sensitivity:@tom.chen
Hi
Why didn't Singxer provide the input sensitivity of the SA-90? Could you share this information with us?
Kind regards
Not uncommon. ATI/Monoprice sell the US-built Monolith 2X for $1200. Pumps out 350W with a 500W dynamic. ToneWinner from China sells one with big huge VU meters on it and more claimed power than that for around $1500 shipped. Emotiva is selling the XPA-2 for $1300. That also hits about these numbers.
Easier to "fix" the "problems" in Class AB than Class D (to roughly quote Bruno Putzeys, who would know). Easy to beat Class D, if you get past meaningless nonsense like 1kHz SINAD on amps with no gain. My 25 year old Mackie smokes a Hypex at 15kHz. But most of the big ABs are not great, yet, except some high dollar stuff. No reason the high volume amps couldn't be, too.
Looks great and promising, now a (also) great Stereo version pleaseThank you for your post.
We have updated the output power
Basic indicators:
Rated power: 90 watts/8 ohms, 180 watts/4 ohms
Maximum power: 122 watts/8 ohms, 202 watts/4 ohms @ 1% THD+N
Ultra low noise level: less than 2.3uV A is weighted, less than 3UV is not weighted @ single ended input low gain
SNR: greater than 140db A weight @ single ended input low gain
THD+N: -110dB A rating of 8 euros and 20 watts;
Damping coefficient: 800 @ 8 ohms
It seems that no one cares about pure analog Class AB amplifiers anymore.
yes.Space is one reason. Small monoblocks or stereo amps fit well on the desk and the power supplies can be hidden.
Not everyone has the space or wants to set up a HiFi rack in the living room. With these small monoblocks or stereo amps, the entire HiFi system takes up no more space than 3-4 novels.
The important reason is probably the relatively low costs and prices. The TPA325x amplifiers in particular can be developed and manufactured much more cheaply than conventional amplifiers, especially transistor amplifiers. Optimization is also much easier. In addition, there are the small and much cheaper housings and very cheap external single rail switching power supplies.
The significantly higher efficiency with the low heat output could be a third reason. Even if these small devices can reach 40°, which is absolutely fine and does not limit their service life (keyword: unfounded heat hysteria), the heat output is much lower than with full-size amplifiers at 40°.
From the pictures it looks like nice built qualityyes.
If a SMSP and a fan heat sink are used, CLASS AB can also be made into a very small size.
Unfortunately, most users (out of ignorance) have huge reservations and fears about fan-cooled amplifiers.yes.
Thank you for your answer. I am a big fan of yours, you are like a breath of fresh wind.Sorry, I thought everyone disliked CLASS AB amplifiers, so I haven't been on the forum recently. No offense. There may be a stereo version in the future, which is already planned. However, this will be an integrated amplifier with volume control.
This is strange.Unfortunately, most users (out of ignorance) have huge reservations and fears about fan-cooled amplifiers.
I have already had a few discussions about this in the forum, but the fear of the fan being audible is too great. It's like speaking against a brick wall.
Your amplifiers will definitely have a higher acceptance among buyers if there is no fan.
oh,thanks.Thank you for your answer. I am a big fan of yours, you are like a breath of fresh wind.
On the one hand, the fans are so quiet that you can't hear them, especially larger fans (80-150mm), and on the other hand, these fans would only be needed at a volume where the noise of the fan would be quieter than that of the devices anyway, so it doesn't matter, no matter which way you look at it.This is strange.
Customers can accept Class D amplifiers with a few hundred kilowatts of noise.
But the fan noise is unacceptable.
In fact, today's silent fans make almost no noise.
HiHi @tom.chen
I have 245V in a mains. Will this be a problem for your amplifier?
Hi @tom.chenthe SA-90 's sensitivity:
5V RMS at low gain,8ohm;
2.2V RMS at hign gain,8ohm;
same with RCA and XLR.
Is there a subwoofer output planned for this amplifier version? For many, a subwoofer is a must.There may be a stereo version in the future, which is already planned. However, this will be an integrated amplifier with volume control.
Hi @tom.chen
If you don't mind, I have a few questions for you.
Which option would be better?
DAC out 2V >>> attenuator >>> high-gain SA-90
or
DAC out 2V >>> preamplifier >>> low-gain SA-90
How will volume control be implemented? If on an integrated circuit, please do it on Muses 72323.
Best regards.
Hi @tom.chen
or
Best regards.
It now makes much more sense to regulate something like this on the digital side before the D/A conversion. This is much cleaner, more versatile and more powerful, especially when making any kind of adjustments to the chassis, loudspeakers and room, e.g. via FIR filters. It also allows a change in configuration at any time, e.g. to operate a passive loudspeaker actively or partially actively.HI
When the SA-90 has low gain, the distortion is lower;
I suggest you use a preamplifier.
I still need to consider the issue of subwoofer output.
The volume is likely to be using relay R2R volume.
At least these are (probably) likely to last a while.different sort of market
i think the market for monoblocks at $1,400 usd is going to be limited
let us say you produce a similar power but much lower quality STEREO class a/b power amp for $700 - even that would be a hard sell on the market and here
funnily enough there's a reasonable interest in the Fosi V3 monos - similar power but $250
i like class a/b - i switched from class d back to my old class a/b but its not a common thing to go back
Could you give some tips on how to best do this?It now makes much more sense to regulate something like this on the digital side before the D/A conversion. This is much cleaner, more versatile and more powerful, especially when making any kind of adjustments to the chassis, loudspeakers and room, e.g. via FIR filters. It also allows a change in configuration at any time, e.g. to operate a passive loudspeaker actively or partially actively.
