SINAD Measurements
Now looking at the specs of my Yamaha MG06 mixer, I see that a line input (channels 3/4, 5/6) nominal level is -10dBu (245.1mV) and the maximum before clip is +4dBu (1.228V).
Wow, that is pretty low. The rest of the mixers in that line accept 2.45 volts as it should be. You may be able to use the pad to fix that?
I just can't believe Yamaha didn't took into account this "standard" and released the product breaking all certification policies or rules. They are in audio business for a long time, doesn't this look strange?
Well, there is no written standard for audio in this regard. The 2 Volt nominal output started with the CD and hence the reason DACs follow it too. Not all sources output this level.
scooter
-10dBV is a pretty common nominal level for consumer products, like CD players
So majority of DACs measured here cannot be considered as consumer products? I doubt we can call them pro audio products (most of them under 100$ and still having +8dBu).
scooter
PAD switches are only for 1/2 channels unfortunately...
What do you recommend Amir, maybe it's better for me to upgrade a mixer than pursue a DAC which has lower nominal output?
Blumlein 88
Longer term, I suggest getting a better mixer. For now there are also DACs that have volume controls (e.g. Topping D50s) so you can use them without anything extra.
scooter
... like a small MacKie VLZ, as an example.
On an upgrade path I'm considering Yamaha AG06, same compact size mixer, USB audio interface, individual compressor settings for 1/2 channels and effects. I already learned a lesson that compressor is a must during drunk karaoke sessions :)
RayDunzl
Central Scrutinizer
Riverview FL
Doesn't the mixer have attenuation for hot inputs?
scooter
Those are level knobs adjusting an output signal level going to the main stereo mix. Channels itself will be overloaded by constant +8dBu input signal. On the other hand, channels 1/2 are equipped with an input gain knobs and attenuation pad switches as well. Neither are on 3/4 & 5/6 channels
RayDunzl
Central Scrutinizer
Riverview FL
Yes, I see that now:
Rja4000
Liège, Belgium
Well, I'd try it first.
Compressor and effect are pretty basic on those...
KSTR
Berlin, Germany
The 2Vrms quasi-standard for consumer digital sources like CD seems to come from the maximum level a traditional -10dBV consumer input should always be able to handle. This -10dBV level is a "nominal" working level (with a slow averaging VU meter indicating "0dB"), not the clipping level, and the actual circuitry always has to have quite some headroom, on the order of 5x-10x, the analog sources of the day required this.
Which amounts to 14dB-20dB of headroom, giving a clipping level of +4dBV (1.6Vrms) to +10dBV (3.16Vrms). 2Vrms is 16dB of headroom, and seems to match the dynamic range (DR) figures of early CDs. Looks like the 2Vrms 0dBFS output was wisely chosen by the Sony/Philips engineers..
Rja4000
Liège, Belgium
Of course, makes sense when you think about it.
Thanks
scooter
I don't need many effects, just reverbs or so.
Regarding compressor, I've seen various reviews on Youtube and it seems there are quite high level of compression level adjustments within Yamaha software for each 1/2 channel, completed adjustments and settings can be saved in DSP and later used by just one button click on the mixer itself (disconnected from computer and used standalone).
Do you have any personal experience that compression is basic and not effective?
P.S.: Sorry for being off-topic...
