- Thread Starter
- #21
The vertical dispersion could be of some interest.
I would wager it's not great, but I'm pretty tired on measuring these things. Lot of work to drag my rig outside. Subjectively one really needs to sit with their ears between the tweeter and woofer to get good results.
I expect very low impedance at some higher frequency beyond the range you tested, but the (digital) amp might still ‚see‘ it. A small resistor might help without sacrifice.
I tested this, it didn't make any difference.
That would solve probs with directivity, and may rendern the nasty cap parallel to the tweet obsolete.
This tweeter seems to just have a rising response when you place it on a bookshelf sized baffle. Every DIY design I've seen shows a similar response up top, and even when using active filtering it needs a shelf to flatten it out. I genuinely cannot stand any amount of elevated treble. It sounds better with the parallel cap.
Lowering the xover point doesn't fix the DI, even if trying ~1khz which is just about on tweeter FS. I'm still showing a DI mismatch at this xover point.
I would need to remeasure the speaker and I might be able to fix it's problems then, but do I want to? Not sure I do. I've built like 6-7 speakers over the past 2 years and I'm kind of tired. I didn't have high expectations for these as frankly speakers without waveguided tweeters tend to not sound good to me. Another issue is the woofer has an elevated response around 700hz that is tricky to get around.
The bass tuning is a bit high, maybe an extended bass shelf is more desirable.
It would still need EQ. If one looks at the cnote data taken by Amir, that one is using a lower point tuning but it's still a good 5db down from the rest of the woofers response. I think this is just about all one realistically get out of this small woofer.
I frequently use some Kali LP6 which have no problem keeping their low end pretty flat down to the port tuning.
