Simple AB(x) switch box solutions and circuits
Hi Klaus, I believe that everyone reading this thread understands this, even without further explanation.
I'm not so sure about this, but hopefully most people will do understand ;-)
Let's keep aware that this is not a full-featured ABX Switch Box, it is just a simple switch box with no other functionality.
To become a proper standalone ABX Test Gear, one needs to implement way more stuff (hardware and a real lot software) than just the actual switching. The switching is maybe like 2%...5% of the total effort.
@mcdn is working on such a full featured gear, and I'm partly involved in that, too. See the corresponding tread in the DIY section.
A little bit more sophisticated, yes :-)
Guys guys …..
Reactions: pma
One more measurement, THD+N vs. output voltage, direct DAC/ADC path compared to DAC/ABbox/ADC path. They are really 2 plots in this image ...
Crosstalk [..]
The coupling into inactive channel is of course capacitive via the relay body contacts and bare wires. The result is thus very good also due to low input impedance of the Cosmos ADADC.
Crosstalk can be eliminated by switching the unused output to ground.
Sometimes I am saying there is always a space for improvements. And it is. Measurement of the SE device must be differential (it was), however the reference ground must be done with external wire to connect the source ADC and DAC (2xUSB issue), to provide clean reference. And now, the low level mains 50 Hz is gone. Plus DX5 instead of D10s.
Of course, and it is in more sophisticated designs, like this.. Here we discuss sole relays, the simplest possible box.
This is the newer version dated 05/2017. Below is the complete schematics and board in pdf files. Some description here (without the speaker path):
These relays might be usable for speaker switch. I will test them. It works with remote control now.
So we have a board with 16 relays (we need 4 relays for 2-channel stereo, but lower relay count would not make the board cheaper), with optically isolated drive circuit, at about $12. Simple IR control at similar cost. Add a metal enclosure at some $35 and speaker binding posts at $5 per pair (6 pairs needed at least). We are at about $100 material costs, + work hours, drilling etc. This is about the minimum to be spent for a usable speaker switch box, if we do not want to buy a finished product.
So, this will be a simple, remote controlled speaker A-B switch box. I will give it a try. 1 amp ==> 2 pairs of speakers or 2 amps ==> 1 pair of speakers.
Last year, I evaluated this type of inexpensive relay board from AliExpress for a curve tracer project.
The relays on the first unit I tested were of poor quality, specifically, the normally closed (NC) contact. When subjected to a direct current (DC) of approximately 3A, its resistance went from 29mΩ to 19mΩ within a few seconds.
Furthermore, the resistance fluctuated at the slightest shock, which I suspect was due to an overly weak return spring.
The normally open (NO) contact was of better quality, under the same conditions, its resistance shifted from 19.25 mΩ to 18.8 mΩ and was unaffected by shock.
A board from another supplier was better but still unusable for my needs.
It's probable less critical for a speaker switch box but I'm not sure I would trust this kind of relay.
Reactions: pma
I have just tested the board with relays. First, I needed to re-solder all the solder joints of the terminal blocks and relays. They were so poorly soldered that some of the terminal blocks could have been manually pulled out from the board ... $12 board, no surprise.
Then I measured distortion, using Purifi 1ET400A with 8ohm load resistance, first direct connection, then with the 2 Songle relay contacts in series. Output power was 2.5W/8ohm.
Direct connection
With relays, measured across the load terminals
So yes, there is a degradation in distortion. Though not horrible, yet, but it may come. See odd harmonics only - typical for contact distortion. We can also see that load power is decreased from 2.556W (direct) to 2.506W (with relays, 50mW less). As a homework, one may calculate relay contact resistance (2 contacts in series) from these 2 power values and known 8oohm load resistance.
Okay, the design would be cheap, easy to operate with IR remote controller, but with disputable parameters.
