Simple AB(x) switch box solutions and circuits
pma
Prague
This is a "review" of a simplest possible AB(x) box comparator that I built in the year 2001 and is still in operation.
This "review" is written as a reaction to @amirm test of the Van Alstine comparator which had very poor measurements with respect to its price and assumed use.
This simple box is bi-directional and allows to connect one stereo RCA link input and split it into 2 RCA outputs, or to connect 2 link inputs and switch between them into 1 output. The same applies to binding posts path that can be used for speaker or power amp switching.
On the front panel there are 2 RCA CINCH connectors, 2 pairs of speaker binding posts and a DIN connector as an input for 12Vdc control voltage. On the rear panel we have 4 RCA CINCH connectors and 4 pairs of speaker binding posts.
The schematics is simple and looks like this:
(C19 must be reduced to 0.1uF or unused. 470uF results in slow/unreliable contact separation)
Inside the unit it looks like this:
The wiring is simple, but let's wait for the measured results.
Measurements
Quick set of measurements has been done with Topping D10s DAC as a signal generator (at -1dBFS output level) and E1DA Cosmos as ADC, at its 2.7V input range (input SE impedance 702 ohm).
Distortion at 1kHz
Direct DAC-ADC
with AB box
The only difference is a small -130dBr 50Hz line with the AB box.
IMD 19+20kHz distortion
Direct
with AB box
Again, the only difference is in very low level 50Hz line.
THD vs. frequency
No difference. The plot starts at 100Hz because below 100Hz the Cosmos adds LF distortion from its input electrolytic coupling capacitor.
So it goes. Almost everyone with basic skills could make his own AB box that would not degrade the signal as the Van Alstine box did.
Measurements
Distortion at 1kHz
Direct DAC-ADC
with AB box
Direct
with AB box
THD vs. frequency
Wow. Thanks for sharing this.
Reactions: pma
ABX is good however it is done.
Or some ASR readers could just read marketing data or fake reviews and spend tons of money on nothing. But often, that's the main thing...
You will always find that people hate surprises if they are proved gullible, in a proper blind test. Same with guitar-related stuff.
Very nice. Quite useful. But it looks like an AB switch, not an ABX.
A suggestion: it would be useful to have potentiometers to equalise signal levels between A and B line level paths.
Reactions: pma
Great result, as I expected from your bench. :cool:
I think you pointed out in the other thread, the performance of the comparator box is critical, but just the starting point of a proper ABX test.
I am calling it AB(x) because the selection of the signal path is driven by 12Vdc control voltage and it was easy to make a controller/randomizer. But it needed a second operator.
Please note that I posted this “review” rather for fun, to show that a relay with good contacts does not affect the signal integrity (even after those >25 years). It was my first quick attempt to make A/B and abx testing. Later, I designed a unit with 2 blue Alps pots to control the signal level (and with output buffers)
However, during testing of preamps and DACs, it never happened to find an audible difference. An audible difference was found only in case of a cheap class D amplifier which had strong dependence of frequency response on complex load impedance.
Crosstalk
Based on very simple wiring based on mostly bare wires I was curious how it would behave re crosstalk to inactive channel. I sent the signal to RCA L channel and measured at the output of L2 and L1, active and inactive left channel outputs. This is the result:
The signal level of 1kHz sine is attenuated of -100dBr compared to the active channel. Going up to 20kHz, the crosstalk is worsened to -80dBr.
We can see some 50Hz induced from mains frequency in the inactive channel, which is still low enough. I also made a recording of a music signal from the inactive channel, and there is nothing heard even at full volume.
The coupling into inactive channel is of course capacitive via the relay body contacts and bare wires. The result is thus very good also due to low input impedance of the Cosmos ADC.
Yes, but that can easily be done off-board with a pair of cheap preamps upstream in the system, to equalise the levels.
Measurements
Distortion at 1kHz
Direct DAC-ADC
with AB box
Direct
with AB box
THD vs. frequency
Is there a comparable ABX comparator box that is commercially available, or do all the double-blind testers just build their own?
Also, I didn't notice anything about potential tell-tale sounds made by the relays. Are they silent?
Yes they exist, you will easily find them by Google, but I have no personal experience with any of them.
Regarding mechanical sound of the relays in this simple box, yes the difference exists and was posted here in another thread. Should be noted that the sound was recorded from open box, with the microphone placed 4cm from the relay body. With covered box it is barely audible, but for the reason of different clicking sound I used randomized sequence of control voltage impulses, as I have already mentioned.
If anyone built these ready to go for (delivered BoM cost * 120%) + $50/hr build time
I bet enough would sell to make say a dozen at a time worthwhile
Dunno about the "easily" part!
I'd already googled "ABX comparator" and "ABX box" and come up with zilch. Just the AVA unit, foobar, and various diy projects, including yours.
It's rather incredible that this vast edifice of putatively scientific insights from ABX testing, with myriad published results, can be produced with no industry standard for tests and measurements. We can all agree, I hope, that widely accepted devices and protocols exist for other measurements -e.g., Audio Precision.
A box from 2001 that out-measures a $1,300 one, love it. Did you ever measure the speaker side with a real amp pushing current through those binding posts? Curious if the relays stay invisible there too.
It really surprises me that Douk Audio or similar outfit hasn't done one of these as a matter of course. But I guess the lack of popularity of the AVA box (even before its reputation was ruined) makes it unlikely. But I can see lots of enthusiasts who would shell out for a $350 audiophile switcher with ABX capability.
This is what I plan to do (again, after so many years, but with better test equipment). The relays in this simple box have maximum rated current of 2A, so this would restrict us to 16W/4ohm, which is still fine.
Long ago I measured various high power relays (20A, 30A) assumed for speaker switch box. After several cycles they added considerable distortion and you might be surprised, they were much worse than these small 2A relays, provided that we stayed below 2A. This is because of the contact material used in the small relay, which is a Silver palladium overlaid gold crossbar contact type. The power relays used Silver Nickel (AgNi) or Silver Cadmium Oxide (AgCdO), both with nonlinear issues after short time.
Measurement with 4.7 ohm load at 8W power
As I was curious similarly as you have been, I made some measurements at moderate power. To me, the result is better than expected.
Direct (no relay)
with AB box
Direct vs. with AB box
Direct vs. with AB box at 8W
0.3dB drop due to contact resistance
Maybe they will after reading the threads here. They are good in web monitoring ;).
Let's keep aware that this is not a full-featured ABX Switch Box, it is just a simple switch box with no other functionality.
To become a proper standalone ABX Test Gear, one needs to implement way more stuff (hardware and a real lot software) than just the actual switching. The switching is maybe like 2%...5% of the total effort.
@mcdn is working on such a full featured gear, and I'm partly involved in that, too. See the corresponding tread in the DIY section.
Hi Klaus, I believe that everyone reading this thread understands this, even without further explanation.
I am looking forward the real build of the "full featured gear", together with test results.
