Simgot EP5
Hey everyone, I’m trying to decide between Sennheiser HD560S and Simgot EP5 mainly for gaming, especially competitive FPS (CS2, Valorant, Tarkov, etc.). Which one is better for gaming?
Probably the HD560s because I'm thinking you'll probably be using it for gaming without applying any EQ, and the HD560s sounds better (more balanced) without EQ than the Simgot EP5 without EQ. For positional audio in fps gaming you don't really want lots of bass as it can muddy the sound cues a bit, so again the HD560s is better on that front.
Oratory published the EP5 measurements :
Like UnheardLab, it's not so far from Harman target with a bit of brightness at 6 kHz but YES, the too elevated bass.
I definitely went back to the AKG K371 for my personal preference. At first the EP5 is fun with this bass boost but it gives a compressed sound in a "vertical way". The bass is too elevated compared to male voices, it masks a bit.
As usual, the K371 seem more neutral, more linear but a bit much darker because of the 4 kHz dip.
"Better a dip than a peak"
Still, the EP5 do a very good job, way better than a lot of headphones measuring badly, and for ~80 €.
That's great! Thanks for letting us know he's measured it. It looks like a pretty nice one to EQ, as the EQ is not working too hard as if you look at it broadly he's only having to take down the treble peak at 6kHz and the bass peak at 100Hz, it's an efficient easy EQ! I'll be trying it fairly soon, I think that's a great omen for this headphone the way this has measured. Eyeballing it, it measures pretty close to the one unheard labs measured which is the one I based my EQ on.
Yes the two measurements are close.
I want headphones which sound good without EQ so I stay with the AKG but for people not bored by EQ, the EP5 are good headphones at fair price with nice confort and built.
The faux leather and aluminium headband is sturdy and lightweight. Maybe more durable than the AKG for which I don't have QC problem but a lot of people have.
Hi everyone,
I bought the Simgot EP5 (also from france @FTB ; ) I was hesitating with the AKGs 371/361 but the build quality and the curiosity made me choose the EP5. I also sent back an Austrian Audio hix20, too much V-shaped for me.
What I wanted to correct quickly after first listen is the light exageration at 105hz and the one at 5900hz, both deserving a -4db. After that it's getting really interesting in neutrality and even imaging.
I also tried to close ports a little or completely, it works very well wih partially closed ports. When done, the sibilance around 5900/6000 still brings too much coloration for me.
So I will try to add some toilet paper below the pads, like Solderdude made in his JT1 review
I will also try the EQ config in APOequalizer from @Robbo99999 (thanks!)
And finally I'd like to try some pads like the Fiio FT1 ones, that look interesting in correcting lows and highs. Here is a comparison beetween EPS with closed ports, and with FT1 pads (from unheard):
(I have to say that oratory's measurement of the EP5 is closer from what I feel on lows and -specially- highs.)
Reactions: CiX
Hi everyone,
Oratory's EQ is really good on this one I think, so I'd recommend to use just his EQ. I don't think you need to bother with messing around with ports and pads if you're EQ'ing anyway. At least you have some measurements there regarding blocked ports and the changed pads but I don't know how comparable the measurements are - as in are they the same unit of headphone, and is it the same person who's done the measurement. Using Oratory's EQ or using his measurement & then doing your own EQ based on it is gonna be the most reliable approach.
It's a really good headphone in my opinion after EQ, the bass is really well represented / impactful / detailed, and overall clarity is really good. At the moment I'm using my EQ'd HD800 and HD560s the most, but it doesn't diminish my opinion of the EQ'd EP5.
Thats great! What do you think about soundstage for a closed back? I think it's not bad :)
You're right Robo, messing around with ports and pads is complicated. But I tried the 10 EQs of Oratory and the sound became small and without life. I'll have to change it a bit, depending on ears and/or models it can sound different.
Note: I put all 10 EQs in Rephase, to export a txt file in APOequalizer, maybe there's a problem with my Rephase parameters.
I've never used Rephase so I can't advise you on that, but there's no need to use that, so instead simply put the ten parametric EQ filters directly in using EqualiserAPO or if you find EqualiserAPO difficult to use then use the PEACE extension that you can download that bolts onto EqualiserAPO and gives you a graphical interface that is a bit simpler to use and understand than the original EqualiserAPO interface.
Yeah, soundstage was fine with the EQ'd EP5. I didn't miss anything with regards to that using that headphone. As the years have gone by I've become a bit less concerned with soundstage, but maybe that's because I tend to use only headphones with what I know from my own experience have good soundstage (HD800, HD560s, K702), and it's been a long time since I've used a headphone that previously I've known to have poor soundstage (HD600), so I don't really think or experiment with headphone soundstage much nowadays. EQ'd EP5 didn't make me think there was something wrong with soundstage though, I really thought overall it was a great experience.
Interesting what you say about soundstage Robo, thanks for sharing your experience.
I didn't know PEACE extension, nice.
I think I did someting wrong in Rephase, I finally put the ten Oratory EQs in APO, it's great now - I just put a little more subbass, it was too dry for me.
Next step will be to find a portable Dac/DSP for it :)
Cool, as I said I really can't advise you on Rephase so potentially can't say to you you're messing something up by using it - but if you know how to use it & you know what it does then don't worry about it. In terms of the parametric filters though - if you put Oratory's filters in right then I can see you having a good experience with the EP5 - at least from my own experience - the bass is really lovely with it combined with the good overall clarity, lovely headphone. And if you find you want to increase the bass (as you said), then that's a completely normal thing to tweak - Harman say that's pretty much an established practice to tweak the bass to your preference.
Super easy to find a reasonable dongle to drive the EP5 - it's easy to drive. My best dongle is the Fosi DS2, so can't go wrong with something like that, even the Apple Dongle will be fine.
Nice, I see it has good reviews, & for a good price^^
