Murmon
- Joined
- Apr 18, 2021
- Messages
- 13
- Likes
- 0
Certainly. Analog sound, detail and silence. All this is the best!
Yes, right. Try it, all this is possible and not as expensive as silent angel, bonn n8 ....
No such thing as a hub any more. Haven't seen one since the 90s. Anything supporting 100 Mbps or higher is a switch.Now on to reality. If you are streaming high def, and have lots of things hanging off a hub, you might do better with a switch.
Do you have any idea of how packet data actually works?
Thanks everyone for the questions!The Silent Angel Bonn N8 does nothing you won't get from a cheap "non-audiophile" switch
No idea. I am a music lover and I listen with my ears.
Start small and then you can refute my arguments.
I think it should also be noted, at least once, in this thread that this explanation isn't exactly correct either, or at least not the whole truth.A lot of streaming protocols use TCP, which means "packet" is not really that important as it's transferred as a byte stream and TCP will take care of re-ordering packets and re-transmit dropped or delayed packets. TCP is most definitely not real-time.
Actually, what has been discussed in this thread actually resemble RTP, which funnily enough uses UDP for transport. But even in RTP there are built in facilities to compensate for jitter, out of order packets and the loss of packets.
I stand corrected, thanks.As a developer you can either rely on TCP's error detect/correction or you can use UDP and rely on it's error detection and write your own correction.
@Murmon has provided one concrete example of upgrading a Zyxel GS-108B v3 switch with a new clock and a new voltage regulator.
An example of what exactly? If I post you a video of me spinning a plate in the middle of the kitchen floor what have I actually accomplished?
Perhaps another approach, like Amir took with power conditions, is to use NetEm to emulate a really crappy home network with high jitter or packet drop or corruption, and show that a streaming protocol (e.g. Roon or Airplay) is impervious to these things. It's really easy to setup a linux host with two network interfaces as a transparent bridge with settable jitter, delay, and drop rates.
Many people want charts, numbers. What for?
I can hear the difference for the better and that's enough for me!
I respect any of your views on the bonn n8 and the like, but tonight in a comparative listening of the bonn n8 with a cheap tp link of € 35, the difference was huge in favor of the bonn n8. With better sound of course...
