Signal Chain Question Topping D10->DJM900NXS->Kali LP6-V2
Querkle
Hello, in my living room i have all sound running through my DJ mixer in order not to have to change cables and connections to my speakers.
the DJ mixer supports RCA Line, RCA Coaxial Digital Inputs, and a USB input into all 4 channels and then gets sent into a 32bit/96 floating mixing processor and out a 32bit/96 DAC to my monitors.
I do notice using direct Balance 1/4 to 1/4 on my Kali monitors sounds better than the 32bit/96 mode than routed through the DJ mixer, but its too much a pain to switch back and forth.
I currently use my computer connected to the TV living room and that is plugged into a topping D10B using the digital output to the mixers digital input as i assumed it might be a better digital transport, but now i'm debating just plugging in the mixer directly with USB into the computer, should there be any difference?
Between PC->USB->D10B->SPDIF->Mixer and PC->USB->Mixer?
None.
