- Thread Starter
- #741
Got the front page too.
Congrats, Thorbjørn, on a great review.The first review of the Saranna is out, from Norwegian magazine Stereopluss.
An English translation of the article (which is originally in Norwegian) is available here:
Sigberg Saranna - Stereo+
It took three seconds before I started to ponder—could a hi-fi journalist possibly use active loudspeakers in their reference system?www.stereopluss.no
Wow!!! Congratulations on the very positive review!The first review of the Saranna is out, from Norwegian magazine Stereopluss.
Do you have any frequency response measurements, along with SPL vs distortion for these speakers?
Thank you very much for the above graphs ... one thing I didn't understand when you said "the rear facing bass drivers don't sum correctly in the measurements...". Is this an issue with the speakers or the test chamber or environment?It has been shared in the thread before, but here they are again.They are difficult to measure in the good way, as the rear facing bass drivers don't sum correctly in the measurements even in the anechoic chamber. So I have made a simulated response, but also sharing the anechoic measurement below.
Response with simulated data below 200hz or so:
Anechoic measurements (reference axis / 10-deg off-axis), inaccurate below 150hz:
Horizontal polar (normalized):
For distortion, please refer to post #670 (page 34).
Isn't the anechoic chamber, by definition, have no echoes or reflections from the source? That is, its supposed to absorb all sounds from the source speaker, reflecting none back to the test microphone, similar to if the speaker is placed in an open field. So the chamber response is the response of the front woofers, with no input from the rear woofers, producing the attenuated response above? And that's what you mean by rear bass not summing correctly?With the test chamber. In the middle of an anechoic chamber the bass doesn't behave the same way as in a normal room, so the bass level is not represented correctly.
If you measured the speaker with it mounted slightly away from the [hard] ground, facing upward with mic facing downward toward the ground/speaker, would the result correlate more with a room response, just with no additional boundaries to muddy the result?Yes, it's even less echoes than in an open field, as the chamber has no floor or ground either. The speaker is on a pedestal above the "floor" and the floor is just an elevated, open grid hanging in mid air.
So yes, the direct sound picked up by the microphone does not correlate with what we would measure (or hear) in a normal room.
Need to get it on a Klippel. That would be interesting.Hm, possibly. So you might get a more accurate level in the bass, but you'll still get reflections from the ground disturbing the result. The easiest is probably to merge two measurements, one of the direct sound and then an additional measurement from the rear and/or nearfield. I'm actually in the process of building a relatively large semi-anechoic chamber for development + QA work now, so we'll see what I can do there.
If the principle of the speaker function is cardioid effects requiring SBIR from the wall behind the speaker, will the Klippel results be interpretable?Need to get it on a Klippel.
Of course it's a smaller speaker but EAC measured the D&D 8c on the Klippel and also outside with the speaker on it's back facing upward using the ground for the rear wall to reinforce the subs, with the mic facing down.
Anyway , congratulations on a great speaker.
That’s exactly what I was suggesting above.That's interesting, looks like a measurement outside like the one done by 8C here might work. Some risk of damaging the speakers though.
And thank you!![]()
Couple of additional thoughts regarding this measurement method.
1. Make the distance from the floor a variable to show how this changes the overall response.
2. Try absorbing material on the ground to limit the boundary interaction to low frequencies.
